Question about LG 50PX4DR 50 in. Plasma TV
Verticle Bars down each side of screen
Hi If you could help me I'd appreciate it. I've an LG 50" Plasma. When in 4:3, 14:9 or Auto mode the verticle filler bars on each side of the screen are grey. I would like them to be black like my 23" LG TV but have no idea how to change the setting. I've been over the manual and still can't seem to find the command. With thanks, Cameron
  • 103 Answers
It would be in video settings mode if avail. Being a plasma it might not be available,this feature is to prevent burn in.
Posted on Mar 22, 2007
SOURCE:
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
What is causing PZ550 Plasma TV to display a frozen image with bars, and then a black screen after restarting the TV? Sounds and TV functions work.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 08, 2015 | LG 50 50PZ550 50 3D Plasma TV
I have a 50" Plasma
Hi, the aspect ratio is set incorrectly for the source material or the screen is simply set to 4:3 aspect (old TV size) manually. There will be a menu function or an aspect button on the remote for doing this. Set it to auto which is usually good enough for most viewing though the ratio may change during adverts and back again for the film on tv watching. This can be annoying so when on tv mode observe the ratio set when the film is on and manually set this ratio, usually 16:9. The display will normally tell you the ratio setting at the point of change so you can do this. I hope this helps.
Steve at Olive Country Computers in Spain
Feb 19, 2011 | LG 50PX5D 50 in. Plasma HDTV
Vizio 50 in plasma screen dim
If there is no auto dimmer on the TV, than the TV needs professional repair work.
Nov 14, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Verticle black bars
Check the connections on the flat cables to the screen. Be sure first to disconnect the power supply from the x and y sustain boards before you disconnect any of the flat cables.you will burn the cables from the stored energy in the power supply, also check cables on c boards at bottom of screen. If this does not fix probably bad panel.
Apr 24, 2009 | Televison & Video
Colored verticle bars, some w/colored snow,picture is still on
It sounds to me like you have a bad plasma panel. Unfortunately you may now be in the market for a new TV if you are not under a warranty of some kind. That issue is unfortunately unrepairable because it requires you to replace the entire panel and therefore is not cost effective.
Jan 23, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
LG 42PX10 Plasma
I just fixed my plasma with same looking problem. Mine is a 42PX11. Cost me $320.00 in parts from Fishwick Electonics. Replaced three circuit boards, crossed my fingers and turned it on and am happy to report it has been working fine since for about 6 months now.
Aug 11, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG 50PX4DR 50 in. Plasma TV Logo
324 people viewed this question
Steve Allison
Steve Allison
