Question about Evesham Voyager 5700 Notebook
Will not boot
The windows XP initial screen appears for about 10 seconds the laptop then resets and starts again. With the recovery disc inserted the disc is read and the pc stops
Factory settings sony vgn-n31z/w
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
Oct 03, 2012 | Sony Vaio VGN-N31Z/W
Reset to factory without disk
which operating system ?
hope this helps
Sep 30, 2012 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
I want to recover my sony vaio laptop with windows 7 OS, i want to get it back to original state to delete all personal installed programs. pls help
hope this helps
Sep 29, 2012 | Sony Refurbished White 14" Vaio...
How do I reboot my ASUS EEE PC 701SD 7" 0.9 GHz
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Oct 30, 2011 | ASUS Eee PC 701 Notebook
Vaic t200 password needed to unlock but none offered. please help
Hi! Welcome to www.fixya.com.
Recover From Within Windows 71Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
2Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
3Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased. The computer will restart and the recovery process will begin. When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition1Turn on or restart your Sony Vaio computer.
2Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine. If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
3Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter." The VAIO Care program will appear on your screen. Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs1Insert the first recovery disc in your optical drive and restart your Sony Vaio computer. The total number of recovery discs varies based on your Sony Vaio computer. The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
2Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
3Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
4Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete. The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system.
Read more: How to Recover Factory Settings on Sony Vaio Computer with Windows 7 ' eHow.com http://www.ehow.com/how_7680511_recover-vaio-computer-windows-7.html#ixzz1SY1sA7Sg
Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Computers & Internet
My computer went to a blue screen and says fatal system error the initial session process terminated unexpectantly with a status of 0x00000000 (0x0000034 0x0010037c). The system shut down.
Dear Sir,
Please have the problem solved by having the system
repaired. This is actually being caused due to a corrupted
or missing system file. Please have the instructions to
having it repaired
Repairing Windows XP using CD installation
The CD installation for windows XP allow you to repair windows whenever there is file missing or corruption or improper function of Windows. This tips can be useful before you opt for a complete format to your computer.
Your first step is to boot the computer using the cd installation.
Below message will display:
Press Enter to setup Windows and accept the license agreement. Then select the XP installation you want to repair and then press R. 1wq9asrj-2-s-.png
Windows xp will copy necessary before reboot. You will be asked to press any key to boot to the CD. nzlmbj8t-2-s-.png
Do not press any key. Windows will boot to installation screen automatically and start installation.
After installation, enter the CD key (windows registration key) to finish repair.
You can now remove the cd from the cd drive and reboot the computer for appraisal
Jul 14, 2011 | Dell Inspiron 1525 Notebook
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
How doI reset my Toshiba Laptop with Vista 64 bit to factory settings?
There are two ways to reset your Toshiba Laptop to factory settings.
First is using Recovery Media Disc and the second is the hidden partition on your hard drive.
If you're going to use Recovery Media Disc follow these steps:
If you have two or more recovery media disc try to insert first the disc that has a label of 1 of 2 or 1 of 3. Then turn of your laptop.
Make sure that the disc is inside. After that try to find the letter "C" key on your keyboard. Now turn on your laptop and keep tapping the letter "C" key. If you have successfully accessed the Boot Menu choose Toshiba Recovery Wizard.
After choosing the Toshiba Recovery Wizard there will be a big warning screen that will appear choose the option yes and after that you will have a series of option. Remember to choose always the first option after the big warning screen appears.
That's it. You will have a message that the Windows is initializing files.
That process will take 1-2 hours for it to finish.
Hidden Partition on the Hard Drive.
Turn on the laptop and as soon as the laptop turns on press and hold down the number 0 key (the number 0 it should be on the top of the keyboard beside the number 9 key) keep 0 pressed until Toshiba leading innovation appears. Usually you will have a beeping sound when you are trying to access the System Recovery of the Hard Drive. That's an indication that you have successfully accessed the Systrem Recovery of the laptop.
Wait for the screen that say Windows is loading files.
After that you will see a big warning screen the choose yes and
Choose 1st option always.
Cx able to initialize the partition.
Disconnect cables and turn off the wireless switch.
Recovery would take 1-2 hours for it to finish.
Nov 13, 2009 | Toshiba Satellite L305D-S5904 Laptop
Can i somehow just re install xp to solve my black screen, i did safe mode and disk check
Yes, you can re-install win xp, just follow this procedure- 1) As you turn on your laptop, start pressing "delete" button.Press it how many times you can. 2) After pressing the button.A blue screen will appear. 3) In that go to BIOS option. 4) In that option you will find and option named 'first boot' or similar like that. 5) Click on that option and change it to cd-rom. 6) save the settings and exit. 7) Then insert the win xp cd, before turning on your laptop. 8) Your laptop will automatically recognize the win xp cd on startup. After the cd is read by your laptop. 9) An option will appear "press any key to continue" or similar like that. 10) Press any key. And you will automatically will be taken to win xp installation window. 11) Press 'enter' to install win xp. 12) Then a confirmation window will appear. Check whatever you want to do to your laptop.
NOTE- installing win xp again will cause you your saved data lost. if you dont want to loose your data then just format 'c' drive of your laptop.
enjoy!! THANK YOU
Oct 12, 2009 | HP Mini 1000 Netbook
Ran the Tshibery disk recovery disk. Completed and
Complete the recovery again but leave the discs in the computer. That way if the computer needs some files while rebooting it will take them off the cd....if not it will load and that will be the end of that. Just remember when you boot the computer for the first time to initiate the recovery, when it says to boot from cd touch any key...that is only done one time when you first initiate the recovery...after that do not touch any key if it says that...just let windows boot on it own. Once windows boots on its own, then you can take the recovery disc out and put it away.
Sep 07, 2009 | Toshiba Satellite A60 Notebook
Evesham Voyager 5700 Notebook Logo
62 people viewed this question
Top Evesham Computers & Internet Experts
Simon Clarke
Level 1 Expert
Lakshman P
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
