Question about StarView SV211K 2-port KVM Switch
Starview 1 box not woking do you have the code and how do you put
It into the box is it with the remote
Dec 16th 08 00: 9c 0e 3c 8d d6 73 80 28
01: f2 46 b1 59 04 61 77 71
Posted on Dec 16, 2008
  • olliewoo315 Dec 16, 2008
    1570 with instalation highlighted in menu
How do you programme a remote to a annalog TV thats connected to a t-box DEC TV and a audiosonic remote universal
Hi Rosemary, You only need to program the universal remote to the set top box OR t-box but unfortunately I don't know of any universal remote controls that include codes for set top boxes, Set top boxes OR t-box are fairly cheap these day and they usually come with a remote.......... CHEERS..
May 01, 2016 | Universal Televison & Video
Will my tv remote work on my converter box?
If the tv remote is the original TV remote, it won't control the converter box (if this is an digital-to-analog converter). If it is another remote, then maybe. It depends on the remote and when it was programmed.
Most remotes are limited to codes for devices released at least 6 months before the remote was programmed. Thus is your TV remote was programmed in late 2006, then it may have the right code. Some universal remotes support the converter boxes; others don't. If you provide additional information on the remote, I may be able to give you more specific details for your situation.
I hope this helps.
(any tv that requires a d-t-a converter box was built before any plans were finalized for the converter box.)
Sep 17, 2011 | Televison & Video
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: . An exact replacement remote for the converter box can be purchased at: . The manual for the converter box (as a PDF) is here: .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
How can i control my cable box through my toshiba remote control? I need the code and step by step procedure. Can send me please.
Tv remotes are only for control the tvs only sorry.Ur cable box have it own remote,used the cable remote read ur cable box owner manual or call ur cable company for help by putting in the Toshiba remote codes for the cable remote to used.
Apr 22, 2011 | Toshiba Ct-90302 Remote Control
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
Hi i have a eurovox max.i can turn the channels over on the box but not with the remote.i have tried 3 remotes with it but it still doesnt it my remote or the box.
If you have tried 3 remotes most likely the problem will be with the remote sensor on the box. There is a common problem with the solder joints for the remote sensor u can test your remote sensor and box sensor with your phone camera if you press a button on the remote and move the camera over it u will see it lights up if it doesnt then remote sensor or box sensor not working. Repeat process for box sensor with camera. Sometimes you can just re-solder the sensor and it will work if not you will need another sensor. Good Luck.
Apr 06, 2009 | StarView SV211K 2-port KVM...
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Not finding what you are looking for? StarView SV211K 2-port KVM Switch Logo
Alun Cox
