Question about HP DesignJet 90 - printer - color - ink-jet InkJet
I am getting error code 21:10
My plotter stoped while cutting paper . Giving error code 21:10 , callHP suport.
  • 20 Answers
It Seems It's AProblem WIth Service Station Or there Couls be a paper jam inside the service station , remove it else replace service station
Posted on Sep 11, 2009
SOURCE: 21:10 error
Hi HotRoddy,
This is a Service station error. Check for obstructions in the service station on the right.
Turn on the printer in service mode by holding down the UP arrow and ENTER keys (simultaniously).
Enter Service Utilities, choose Unlock Carriage. Turn the printer off and move the carriage to
the center of the printer. Turn the printer back on. The carriage and service station should
return to their home positions.
If the error returns on power-on, the service station will probably need to be replaced.
Parts and diagrams can be found at partsurfer.hp.com.
Hope this post was usefull for you.
Thanks,
Robosoft.
Posted on Jan 05, 2008
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
frankzjm
  • 191 Answers
SOURCE: I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
Posted on May 21, 2009
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
you would need to purchase a service unit and replace this is a common fault
HOW TO SOLVE ERROR CODE 79.2:04 IN MY HP DESIGNJET PLOTTER?
To answer your question in regards to a list of error codes on a diagnostic test, I have never seen a list and I have been looking for a really long time. From my understanding, the diagnostic report means more to the engineers. Usually each digit represents some aspect of the test. Are you having problems with the printer or are you just trying to understand the test page that printed off?
May 11, 2016 | HP Office Equipment & Supplies
I have Canon ipf 650 , it doesnt show any eror, the problem is it is new plotter, printed very few, and stoped printing only empty sheets were coming out, we changed printhead and again the same, empty...
With this type of plotter there really is very few possibilities. Replace the ink cartridge with a manufacturer original cartridge. If that doesn't work, change your paper. If still no print, send it back to Canon on a warranty replacement.
Aug 22, 2013 | Canon imagePROGRAF iPF650 largeformat ...
I have hp t610 plotter and it incurred paper jam
Check the carriage belt for wear. Is there an error code?
Aug 19, 2013 | HP Designjet T610 InkJet Printer
Paper loaded incorrectly.remove paper in HP plotter T610.
T610 with "paper loaded incorrectly" error. Finally removed the paper roll completely and still had error. Opened top, but no signs of paper. I walked behind plotter and on the left , in the paper path ,I found the paper sensor using a flashlight. I got on my back and reached underneath to remove the plastic cover securing the paper sensor and the sensor itself. The sensor was dirty. Blew it off, reattached it and the error disappeared.
Jul 21, 2011 | HP Designjet T610 InkJet Printer
Hi, I am using an HP Designjet 4520ps plotter and am getting error 84.16:01 - Possible paper jam. There is no jam, it occurs somewhere in the middle of a print job and renders the job a waste. Any...
84.16:01 is a BT arm failure.
In the diagnostics submenu, go to 2.2 BT Arm test. Press ENTER.
If you have a failure, The front panel will display System Error Code 01.0:10.
At this point call HP if you still have a warranty. Otherwise, call a trained DesignJet tech
Jun 13, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
What is the matter with "calibration error (1042)" in plotter?
HP actually recommends that you contact them directly when you get this type of error message.
I can provide a link for you to access their troubleshooting online, at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=82218&prodTypeId=18972&prodSeriesId=82218&objectID=bpp02995
where you can click on the contact HP link in calibration errors to receive further assistance.
Here's that link:
Click here for information on contacting HP support at http://h20000.www2.hp.com/bizsupport/TechSupport/CallHP.jsp?locale=en_US&docIndexId=179680&taskId=101&prodTypeId=18972&prodSeriesId=25301.
If that doesn't interest you, you can browse the HP support forums, and you will find other examples of printers like yours with the same or similar errors, and HP experts who guide them through the fix. http://forums13.itrc.hp.com/service/forums/bizsupport/categoryhome.do?prodSeriesId=82218&lang=en&prodTypeId=18972&categoryId=414&cc=us&admit=109447627+1238315749385+28353475
That's my best advice for a quick solution, to go straight to the source. After all, they have the most experience with these things...
If somehow I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 29, 2009 | HP DesignJet 5500PS InkJet Printer
Hp designjet 450c error lights
Take all cartridges out while the plotter is on,then re-insert them one by one and watch the ready light flash after each insertion.If it doesn't flash that could mean 2 things,either the cartridge is bad or the contacts on the carriage are dirty or the entire carriage needs replacing.
I tell all of my dj-4XX customers to check the spittoon assembly(on the inside,right side)for ink buildup. If it looks clogged,you can temporarily scoop the ink that solidified out,but eventually it(spittoon)will need replacing.
Hope this helps
Jan 09, 2008 | Xerox Phaser 7750DN Laser Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
HP DesignJet 90 - printer - color - ink-jet InkJet Logo
228 people viewed this question
Ben Johnson
