Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC660CN - asnwer machine message length too short
On the Brother MFC660CN combo fax/printer/answer machine we cannot find anything in the instructions to extend the answer machine message time for the greeting and also the recording, its at 20 seconds at the moment which is how it came, do you know how to alter this as its no where near long enough, people are having to call twice just to leave their contact details....lol Please help. Thanks, Craig.
    Scholar:
  • 135 Answers
Here is a link to the manual for a very similar model: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX580MCMFC660MC.pdf On page 9-5, it describes how to extend the recording time to a maximum of 60 seconds.
Posted on Mar 21, 2007
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Answer phone message
I would like to change my brother fax -T94 machine from French to English and also to set up an answer phone message on it. Thanks Denis,
Apr 01, 2009 | Brother FAX-T94 Plain Paper Thermal...
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
http://www.fixya.com/support/p170643-brother_fax_930_all_in_one_thermal/manual-1604
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
Cannot receive faxes
the brother I/F 885MC ( MC stands for message center ) it has a built in answering machine.
to use the built in massage center you need to press the receive mode key till the display reeds
( MSG CTR) next to the time & date
the way the fax need's to be hooked up is from the wall jake to the line jake on your fax machine.
anything you need after that you go from the ext. jake to your ansering machine or extra phone.
if you don't have owners manual go to www.brother.com you can down load manual
hope this help
Feb 11, 2009 | Brother IntelliFAX 885MC Plain Paper...
No fax reception
Send will work on any phone lines
fax machines are often set to only answer 'secondary' ring tones, double triple or higher. When the line was repaired the phone company may have dropped the special tone off your secondary fax line number, fax will not answer without that tone.
Check in the fax answer settings, what the ring tone is, specific instruction on menu settings in your user guide,
Ring your fax line, and check the tone.
If single number fax/phone, check that the fax is set to asnwer all calls then pass on non faxes
Jul 11, 2008 | Brother IntelliFax-2820 Laser Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Mfc-665cw
I need a replacement cd for MFC_665CW. How do I attain one?
Dec 03, 2007 | Office Equipment & Supplies
Answering machine
I have the same machine, and as far as I know, you need an answering machine to effectively do that. Voice mail doesn't work well, according to the manual.
Aug 20, 2007 | Brother IntelliFax-2480C Fax
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
ctnozil
Victorman
Victorman
