Question about Samsung SyncMaster 940BE 19" LCD Monitor
Blank screen My prob is i have a samtron 94v when i plug it in without connecting it to my pc i get a message saying check connection i know what that means but......... when i connectit to my comp the screen gose black and i get nothing have try 7 differets cables but still same black screen is my monitor broken its a samtron 94v 19" lcd
  • michelle1982 Dec 19, 2007
    my screen is always blank ive checked all plugs and are ok, when i turn all power off then back on a message comes up on the screen saying "not in optimun mode, reccomended mode 1074x68 6011/" what does that mean
viziks
  • 220 Answers
SOURCE: Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Posted on Jun 16, 2008
SOURCE: Samsung Samtron 94V N Screen setting problem
I have the same problem with my 94V monitor, It always shows the box with the resolution, and often I can use my PC with TV display.
But the strange thing is, that I use this monitor for about 3 years, and I never had such problems, just int he last couple of months.
My monitor is still under warranty. Have a chance to repair or replace it with a new one?
Pls, help
Posted on Jul 13, 2008
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
budmrtn
  • 11361 Answers
SOURCE: samtron 94v keeps giving a resolution setting
It wants you to set your PC Video resolution to its native resolution, 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 24, 2010
  • 11800 Answers
SOURCE: i have a samsung 17''
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Posted on Oct 03, 2010
Problem with setting up PC mode on my LE40S7 LCD TV
hi it shouldnt matter to much its just a guide line just might mean you get a less clearer picture if you was watching say a dvd but your telly should still let you acess this menu have you tried acessing the menu without the laptop plugged into it let me know ok
Feb 11, 2008 | LG 42LC2D 42 in. LCD HDTV
I have a samtron 74v and upon booting up the screen stays black and a message flashing across my screen says "no optimum mode, recomended 1280 x 1024 : 60hz" but how can i change the resolution and...
Running XP? Boot the PC in safe mode (hit F8 key while PC is booting up and select safe mode), then set the video resoltuion to 640 x 480, reboot into regular boot up, reset the video resolution to 1280 x 1024 @ 60Hz.
Mar 19, 2010 | Samtron 74V 17" LCD Monitor
Hi, Recently I bought a bluetooth software for my lenovo to get the pictures from my phone to my computer. But, while the downlaoad, the network magic gave me the notification of not being connected to...
Please clearify ur prob............i cant understand ur prob..............are u getting prob in file transfer or u r not able to connect to internet using ur phone's BT..................if the prob is about net then check if ur phone can support PAN service i.e. personel area network............or u can connect through pc-suite please mention ur laptop & mob model
Sep 13, 2009 | Lenovo ThinkPad R61i Laptop
No video output from my computer.
Are you using an ON-board graphics adapter or a separate VIDEO CARD? Some motherboards lets you set the video output to "DISABLE ONBOARD GRAPHICS" if you have installed a video card (BIOS). You may have plugged the monitor cable to the onboard D-sub connection instead of using the Video Card D-sub connector.
Normally a flashing green power light means the input it receives from the video output is too much. You may have set the resolution too high or the bit depth too high. Consult the monitor manual on the rates it can handle. To be safe, try starting the computer on safe mode just to check if it is indeed the problem. If it boots properly and you can see your desktop, then there's a chance that the setting was too much for the monitor to handle.
Hope this gives you an idea.
Mar 15, 2009 | SAMTRON 94B 19 inch LCD Monitor
Perhaps other than the screen resolution you need to also lower down the refresh rate (found in the advanced tab of the display properties).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Samsung 94V 19 inch LCD Monitor
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 94v 19nch problem helpppppppppppppppppppppppppppppp
If it's still under warranty I would call for repair service. It sounds like typical internal power supply trouble that needs electrical troubleshooting.
Jan 10, 2007 | Samtron 96BDF 19" CRT Monitor
Samsung SyncMaster 940BE 19" LCD Monitor Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
