I have just bought a 19" H D Ready LCD T V with built-in Digital Tuner Model Number T19L1638. I would like to improve the sound by using external speakers I have a Hi Fi amplifier and am wondering if I could use this to connect to the television and then run the speakers from the amplifier, If I could use this amp. could you tell me how to connect it and what type of cables I would need? If I am not able to use this amplifier can you suggest another piece of equipment for me to use? Thanking you in anticipation.........Ivan Martin 4 William Street Poyntzpass Newry Co.Down BT35 6SS
  • kandimart Dec 16, 2008
    thank you, problem solved
    President:
  • 2,992 Answers
If the TV has audio output jacks then all you need to do is run regular audio cables (shielded cable with RCA connectors) from there to the amplifier. It would be just like hooking up a CD player or any other source. Take a look at the available connectors or refer to your owner's manual.
I'd be very surprised if he set doesn't have such outputs. They seem to be standard today.
Posted on Dec 16, 2008
Plug in head phones to tv/no sound
If no sound from speakers or headphone likely audio circuit issue but check to make sure main speakers not switched to off or external.
Nov 04, 2012 | Toshiba 19AV505DB 19-Inch Screen Hd Ready...
I have a DP50842 Sanyo LCD tv. does it have a digital tuner built in? if so how do i use it?
Here are the specs, it has a digital tuner:
http://us.sanyo.com/LCD-Televisions/50-Class-49-5-Diagonal-LCD-1080p-60Hz-HDTV
If you do not have the owner manual google the model number with "manual" to try to find it.
Nov 04, 2012 | Televison & Video
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Pressed re tune on our 19 inch lcd tv with built in free view now the tv will not work tv on standby will not turn on no picture no sound
Hi friend,
Can you mention your product brand and model name so that an exact solution can be provided.
Your new TV has a digital tuner built in, which means it is ready to receive the Freeview signal by simply plugging it into your aerial socket.
I guess you just need to switch it off then unplug all the cable. leave it for an hour then again reconnect them as directed. I hope this will work.
Gud luck.
Oct 03, 2009 | Televison & Video
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Can't get digital tv channels.
The W1700 is HDTV Ready but it does not have an internal digital tuner, it only receives NTSC coded signals, not ATSQ/QAM coded signals. In order to see tv in HD you will need an external tuner with component or DVI output that you can connect to the monitors inputs.
Jerry
Jan 04, 2009 | Dell W1700 17 in. HD-Ready LCD Television
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
I have TV Model #DS27425. Does it have a built in digital tuner, or will I have to buy a box to be ready for HD TV? Thanks. daisypc@insightbb.com
This particular set does NOThave a digital tuner. However, if you have cable or satelite, a converter will not be needed. Only if you use an external antenna will you require a converter box.
Dan
May 08, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
