I have a 42 in Sylvania 6842PEM. When it warms up, it will shut itself off. I power it back on, it may stay on for seconds or 30 minutes. Any ideas?
    President:
  • 2,992 Answers
If the set appears to operate normally other than the shutdown, it may be a case of either a thermal problem in some component or bad solder connections. I'd suspect solder connections first since they are a major source of trouble in today's TV's. Unfortunately, these problems can be hard to track down. Spray cans of cooler (similar to spray duster for computers) can be used to try locating a thermal problem. Gentle tapping on the circuit board with an insulated tool and close inspection can help find bad connections. Working on an operating TV exposes dangerous voltages and fragile components, so care must be used. If you are not experienced working around electronic circuits, you might consider getting a professional to give an estimate for the repair.
Posted on Dec 16, 2008
TV wont stay on longer than 15 minutes
Sounds like your power board is shutting down as it gets hot. I would get prices for and replace the power board!
Mar 18, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Aug 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
Tv turns on and then right back off
it sounds like one of the boards are going out I would call sylvania and check with there service dept maybe they can send a tech and part out under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Hi I have a sylvania 6842pem 42 inch plasma. when turning the television on it makes a weird screeching noise then goes to stand by. what can the problem be thanks for the help
your transformer on your power supply is bad, i would recomend replacing the power supply, usually when the transformer goes bad , it damages other things on the board, should be around a 200$ part
Jan 11, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Power Supply
No. They are entirely different. Panasonic was the supplier of the 6842PE and Funai was the supplier of the 6842PEM.
Oct 18, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania Power Board
I had the same issue. Turned out to be a blown capacitor on the power board.
<a href="http://s133.photobucket.com/albums/q68/rwlib3/?action=view&current=DSC_0426.jpg" target="_blank">
Jun 15, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sony LCD Projection TV turning OFF!!!
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Standby mode
It happened to me.. a FAx to Enrique. in California.
May 01, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania 6842PEM
Have fixed a bunch of those as a Sylvania ASC. There is a small ceramic capacitor on the main power PCB that has ruptured. It must be replaced with a different part, a special type of capacitor, or it will just fail again. Sylvania had recommended replacing the main power PCB rather than repair because sometimes there was additional damage on the board, however replacing the capacitor fixed every one that came to us. I preferred that because some electrical voltages have to be adjusted if the circuit board is replaced with a different one.
Mar 28, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
