Question about Pioneer Premier DEH-P580MP CD Player
Ipod will not charge while connected to radio
I have a pioneer DEH-P580mp car stero with the supplied cable for an IPOD. I ahve had a second generation IPOD NANO connected to it for the past 2 years. I just received a new NANO, (third generation software version 1.0.3). The music plays fine but when connected to the stero a message comes up that says that charging the unbit is not supported. The IPOD goes dead after several hours of playing. The music pplays fine, it just doesn't charge. is there some kind of adaptar I need. The older IPOD worked and charged fine.
  • Anonymous Dec 31, 2008
    I have the same problem. I have an alarm clock with an I pod port. It charges my older I pod nano just fine but will not charge my girlfriends new Nano. It also does not work with the older (non apple plug-in charger)
Benimur
  • 6966 Answers
SOURCE: DEH-P580MP
If you are referring to the presets tuner station settings being deleted when powered off and or the clock resetting its time, then you have to verify that the Pioneer DEH-P580MP is wired as follows:
Black - chassis/body ground/GND
Yellow - always on/constant B+12 such as the + terminal of the battery;
Red - switched on B+12 such as the ACC of the IGN switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 28, 2008
  • 328 Answers
SOURCE: IPOD functions
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Posted on Dec 31, 2008
  • 10 Answers
SOURCE: Pioneer DEH-P5100UB radio and 160GB iPod problems
so then its the ipod m8 if your friends 1 is working perfect den you should of new it was your ipod
Posted on Oct 31, 2009
so_cal_steve
  • 25 Answers
SOURCE: Pioneer DEH-P580MP radio muted, can not
there is a short somewhere. check your speaker wire on the stereo to make sure none of them are shorted. also, check the speakers to make sure none of the speakers themselves are short (shorted voice coil). disconnect one speaker at-a-time to find the shorted speaker.
Posted on Jan 29, 2010
hawk127311
  • 350 Answers
SOURCE: just purchased a 32 gig ipod touch . the unit
It appears as though you are attempting to charge the ipod with a cable that is not compatible. Some newer ipods cannot be used with older chargers and adapters for cars. Apple does this to maximize their profitability and in my opinion rip off consumers.
My daughters new ipod will work on her old FM adapter in my car but it says it does not support it on the ipod itself. It will transmit through the wire, but will not simultaneously charge it as the older ipod did both.
It is similar to cell phones and batteries. If you own the original razor and upgrade to the next generation razor, the usb connectors are different (hence the chargers will not work) and the battery connections are different so you cannot interchange batteries between the two. Even though you would think Ipods are Ipods and everything should be interchangeable, they are unfortunately not.
I hope this helps and good luck!
Posted on Feb 01, 2010
I have a pioneer dehp6800mp and i want to install a ipod adapter cable, will the pioneer cd i 200 work? and will it also charge my ipod while its plugged in?
You would need the Pioneer CDIB100 iPod adapter instead.
It might charge your iPod, but it does not charge some iPod devices such as the Nano, iPod Touch, and iPhone.
Mar 03, 2011 | Pioneer DEH-P6800MP CD Player
I have a Pioneer DEH-P4150UB car stereo with usb-ipod connection. This was working this morning however when I connect the ipod now there is no volume coming from the system. The tuner works on the system...
you can try a soft reset on ipod by holding the menu and center button at the same time for 10-15 seconds and/or reset your radio by taking face off of it and pushing the reset button on the stereo too.
May 19, 2010 | Car Audio & Video
Pioneer- ipod doesnt have bass
On the EQ on the ipod turn it to bass boost if not try a new cable
Feb 12, 2010 | Pioneer DEH-P7600MP CD Player
Oct 31, 2009 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Pioneer DEH-2700 with iPod????
if your stero has an ip-bus connector then the items you require are on ebay as pioneer aux input.
Sep 02, 2009 | Pioneer DEH-2700 CD Player
Can I hook up my Ipod to this sterio, A deh-1800
This radio has no IP-Bus (Pioneer's peripheral plug in) plug on the back of the unit or any connection for USB or 1/8" stereo headphone jack on it. You will not be able to conect an iPod to this unit. Visit the website at www.pioneerelectronics.com to see their current iPod solutions. They have multiple head units that allow for you to charge iPod and iPhones as well and give you control through the head unit or through the iPod itself.
Jun 20, 2009 | Pioneer DEH-1800 CD Player
Help with ipod connection to cd player
You must use 1 of 3 methods to connect your iPod
1. FM modulator to wirelessly broadcast on a low FM band
2. iPod 3.5mm male/male direct connect cable.
3. iPod USB connection - with Pioneer iPod adapter module.
The direct connect 3.5mm port is on the back of the unit. One plugs into the radio - one plugs into the iPod headphone port.
Click HERE for your owners manual in PDF format.
CLICK HERE for the installation manual
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
My pioneer DEH-P6000UB doesnt read USB
I have a pioneer dehp-6000ub but there is not cord for the usb at the back,, what cord if any can I use to use a usb drive on it..
Dec 28, 2008 | Pioneer DEH-P6000 CD Player
Ipod hook-up
those are rca outputs, if the radio is sat radio ready it should also work with pioneers ipod controller they are about 50 bucks it will charge your ipod as well as let you control it through the radio.
Feb 19, 2008 | Pioneer DEH-2100 CD Player
Pioneer Premier DEH-P580MP CD Player Logo
136 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
