Question about GE Profile JTP18 Electric Single Oven
Ge oven jtp18 broiler mode
Has any solutions been found for oven going into broiler mode without humans anywhere near it. Did it twice today and finally told my wife to kill breaker so it won't burn down house. Like other post, keypad died and only clear worked. It asked to have start pressed but start didn't work. After turning power back on, seems to work fine, all buttons and functions. Must be a relay??? Key pad or board more likely to be problem? Noticed on repaire clinic, boards have been changed as to wiring. How hard to replace with this new type of board? Thanks, Bill
Mine started doing this also. It is the "F7" error reported elsewhere, and it means a bad board or bad connections. I'm in search of a diagram or something to tell me how to open the face up and look at the contacts to the board.
Posted on Apr 01, 2007
I used the oven in the house we just purchased (a GE wall oven JTP18 and after I turned it off a fan kept running. Is that normal?
Yes, the program and thermostat calls for the fan to cool the electronics, without that you can loose the electronic boards. Normally the fans will shut off once temps drop to 200 degrees Fahrenheit. Enjoy your new home.
Jul 08, 2011 | GE Profile JTP18 Electric Single Oven
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
Can I clean an GE Profile TruTemp oven with soap and Water without ruining it?
Yes, soap and water is fine. You can use any mild soap. Just do not clean with oven cleaner.
Please rate solution
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
F7 code on a JTP12 oven range; sometimes it beeps, but now it does not beep. The clock is working; the other buttons do not work; the oven does not work. The code goes away once ot twice every year for...
This is a common problem with an easy fix.  I have fixed mine with the following solution, and it is still going strong
http://www.fixya.com/howto/h155060-dreaded_f7_error
good luck!
Dec 20, 2008 | GE Profile JTP18 Electric Single Oven
JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Aug 17, 2008 | GE Profile JTP18 Electric Single Oven
GE JTP15 oven shuts off
Mine was doing the same thing all day today. All I know is when it was cool I lifted up a bit on the lower burner an inch or so, and set it down. Next thing ya know, you guessed, it, it's working again...Not sure what's doing it, will keep checking for a solution.
Jun 10, 2008 | GE Profile JTP18 Electric Single Oven
Replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
Feb 04, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
64 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
