Question about Dishwashers
What sealant is used on upper spray tube on GE dishwasher?
We have a leak in the area of the upper spray tube on our dishwasher. The design is such that it is susceptible to leaks. The manufacturer put a sealant on at the factory. I would like to know the type and brand of the sealer that was used here.
    President:
  • 2,651 Answers
You can you a tube of G.E. 100% silicone sealent, available at the hardware stores. just make sure its 100% silicone ,not caulking. after repairing donot use t he machine for at least 24 hrs
Posted on Dec 16, 2008
Dishes are not getting clean. Dishwasher does not take off the smallest speck of food. Hot water works. Cycles sound the same
There could be a couple of things that might be affecting the cleaning ability of your dishwasher.
First,there is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My children used to put large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, it could be that the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Aug 14, 2011 | Frigidaire 24 in. PLD2850 Built-in...
My kitchenaid dishwasher the water does not get to the upper rack...and the dishes on the second rack on not clean at all....
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
Jul 17, 2011 | KitchenAid Dishwashers
Water does not enter upper tier in my portable dishwasher
Jul 04, 2011 | Dishwashers
The top sprayer does not work
Jul 04, 2011 | Maytag Dishwasher
Dishes do not come clean
If not, then the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Upper spray arms not spraying water
It sounds like you have a model that has a pot washer cycle that blocks water flow to those arms. What cycles are on your keypad? Sounds like you have it set or single rack wash
Dec 08, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Sep 02, 2008 | GE Profile PDW8400J Built-in Dishwasher
Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
Aug 04, 2008 | GE 24 in. GSD4060JSS Built-in Dishwasher
Dishwashers Logo
233 people viewed this question
Top Dishwashers Experts
