Question about Hitachi 60GB Travelstar 5K160 Ultra ATA/100 Notebook ATA-100 Hard Drive
I have a HITACHI 60 gb hard disk. tried to install os but "cant find any hard disks" appears. i can see the disk in the BIOS also suse linux does not find the same. it is a toshiba laptop i am using. will be gratefull if any assistance
    Genius:
  • 1,019 Answers
there are many reasons why, the computer would,nt find or see the Drive.
1:) the laptop drive, may need formatting.
2:) the drive, is not cabled correctly.
3:) the drive is faulty.
go into the bios setup, usually F2 Or esc Or Delete at setup. options sometimes appear briefly on screen. ** to enter setup press F2 Or similar**
find boot sequence or bootup order. and set the CD/DVD to become the first boot device.
Put your setup-install disk, in the dvd drive.
When rebooting the system, the computer will start a setup from CD/DVD. this will tell you that the drive is not found, or needs to be formatted. follow the on-screen options.
Finally, certain laptops only recognise, a drive of a certain size. install the original to see if this still works. Also check there are no limitation jumpers on the old-drive. ( small plastic bridging pins )
Mike @ compurepair.
Posted on Dec 16, 2008
MY QUESTION IS HOW DO I Disable the "SECURITY FREEZE LOCK" on my hitachi HTS54503289a300, 320 GB sata hard Drive? originally WAS INTALLED IN MY ACER TRAVELMATE LAPTOP NANUFACTURED IN 2012 BUT THE LAP
Maybe if you can format the disk-but you loose data, maybe there is a program that can do it, probably in linux, or bootable itself, maybe ask acer for master password or something, if you still own original laptop and it runs then try to remove disk encryption while the hdd is accessible with laptop (i think its in bios), otherwise the hdd may be unusable to prevent data theft. you can plug any sata hdd into any sata device if you can hook all the cables, no compatibility issues there. try googling and youtubing for more answers
Sep 14, 2014 | Computers & Internet
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
It wont boot, but read corectly at bios screen, but when i try to reinstall an OS such as linux ubuntu, win xp and win 7, it says that cant find any HDD..@ linux Os, its readable but when we try to format...
I would recommend using a boot disk and run chkdsk (windows boot disk) or fsck (linux) This will help fix bad sectors if you use the correct options. USe the "/?" in windows for help and "man fsck" in linux.
Good luck and let me know how it goes.
Joe
Feb 15, 2011 | Fujitsu - MJA2160BH 160 GB SATA Hard Drive
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Installation roblem
bro make perfect partion of ur hard disk............
Dec 01, 2009 | SuSE Linux Enterprise Management Pack...
Harddisk not detected in disk management but recognized in bios
Does it show in the devices? If it is, check and see if it is disabled. If not, check the jumper settings on both drives, and check your bios settings.
Sep 02, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hitachi 60GB Travelstar 5K160 Ultra ATA/100 Notebook ATA-100 Hard Drive Logo
152 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
