Question about Konica Office Equipment & Supplies
Waste toner box
I've just replaced the imaging unit on a bizhub c650 and put everything back together as it was but i'm now reading a 'install waste toner box' message? help!!!
  • Konica Master
  • 6,680 Answers
The waste toner box did you happen maybe break the a small black piece off the waste toner box there is slot for the clear section on the back of the old toner box and you can tell by looking at the machine where the sensor is for that in middle. there should be to the right lower of the machine inside where the toner box goes two slots one handles sensor that tell the copier the box is installed and another for half full box. Have NEW one install it. make sure your toner box has those parts that stick out to accurate those sensors.
Posted on Jan 17, 2015
Soulvisitor
  • 1113 Answers
SOURCE: Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Posted on Oct 31, 2007
tech435
  • 284 Answers
SOURCE: "replace waste toner box" error
sorry there is no quick solution you need a tech to go into service mode and reset the counter
Posted on Nov 03, 2008
SOURCE: I have a message that
After looking on the net if your printer is under warranty, you should call Kyocera Service Rappresentative or an Authorised Service Centre as Kyocera is not releasing how to empty or clear the waste toner box and if you do you will woid the warranty.
Posted on Dec 02, 2008
  • 1894 Answers
SOURCE: bizhub c650 printer: i replaced
i think the waste ink tank is the problem.. please see to that the waste ink tank is replaced..
Posted on Dec 16, 2008
  • 66 Answers
SOURCE: Bizhub C351 Magenta Image Unit Problem
The C531 uses 4 toner cartridges and 4 corresponding imaging units. Each imaging unit has a waste compartment for the residue toner not transferred to the Image Transfer Belt (the waste bottle is for waste from this ITB). The residue toner could be reused.
It does not sound right that after 3-4K pages you have to change the IU. Just to be sure the IU you replaced looks like this?
ef6970d.jpg.
Each IU should last about 50K pages (ie to be replaced after 5 toner cartridges).
Posted on Jan 14, 2009
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Change the waste toner cartridge
Open the front door. The unit next to the yellow image unit is the waste toner box. push the little tab next to it then pull it out install a new one good to go.
Feb 23, 2015 | Konica Minolta bizhub C250 All-In-One...
Bizhub250 - waster toner box replace
open the front door to your left next to the yellow image unit press the button an pull out the waste box and install new one.
May 07, 2014 | Konica Minolta bizhub C250 All-In-One...
C452 water toner
replace the waste toner box lower section below toner section is in front of the image units
Apr 30, 2014 | Konica Minolta Bizhub C452 Copier
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Bizhub 250: is the waste toner box at top of drum unit?
there is no waste toner box in bizhub 250/350.the thing which you are calling the waste box is not a waste box.that thing is "Toner Recycling".
Aug 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Hi i have A problem with Konica C650 , error number is C2204 , i have open and close the front door but noting change , my machine has stoped working , please help me
if the waste toner box was recently replaced either it is defective or the waste box sensors need to cleaned or replaced the sensors are located on the front door on this machine if you have some canned air blow them out and or replace the waste toner box
Nov 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
ef6970d.jpg.
Jan 14, 2009 | Konica Minolta bizhub C351 All-In-One...
74 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
