Question about Toshiba 50H81 50" Rear Projection Television
My T.V. has a funny color .. more of double viewing with purple and green what can I do to fix this?
MyT.V. has a picture which was always properly colored. Recently,seemingly overnight, the color is primarily purple and green uniformlyover the entire screen with a double view of people and words on screen
What is the problem?
and i dont know what degaussing is
When I'm in convergence mode the red cross seems to reach maximum movement and still doesn't quite allign with the blue and green. This causes color separation in the top right and bottom left of the screen.
  • Anonymous Mar 08, 2009
    My Toshiba TV appears to have three primary colors Red, Blue and Green I am able to pull the red and blue together when adjusting it but the green will not align with the other two, any suggestions and is this a repair I can do?
  • Anonymous Mar 28, 2009
    the picture is double with red and blue lines
    President:
  • 2,992 Answers
Your set has a problem with its convergence circuitry. In many cases this can be simply failure of solder connections to the output integrated circuits due to the heat they generate, and resoldering them fixes the trouble. This is a repair you might be able to try for yourself if you have experience with electronic soldering. Or there might be component failure which would require the equipment to isolate and replace the bad parts, which is a repair level best left to professionals. In some cases where the set has digital convergence, the failure might be in the computer control portion. This means the repair might range from only a very few dollars in parts to quite a lot of dollars, plus whatever labor rate the servicer charges. If you aren't looking for an excuse to replace the set, getting an estimate on a professional repair would be the best suggestion.
Degaussing is deliberately applying a magnetic field to the face of a picture tube. This is done to neutralize the effect of other magnetic fields that can cause color distortion. Degaussing isn't done in projection sets because they have separate tubes for each color.
Posted on Dec 16, 2008
2 Suggested Answers
  • 8 Answers
SOURCE: My T.V. has a funny color .. more of double viewing with purple and green what can I do to fix this?
Degaussing means to demagnify. Not applicable with a projection tv. You have a severe convergence problem. Either a component failure, a speaker or other powerful magnet in very close proximity or someone figured out how to adjust (or misadjust) it.
Posted on Dec 31, 2007
The picture has colored shadows and doubled images. People are doubled shadows are red green purple. I would like to know if it worth fixing the tv is about Ten years old. Thank You
In a nutshell, the convergence ICs have failed. The cost to fix by a service company is likely about $300. You may find someone who does it on the side for around $150.
If you are happy with the picture, you like the tv, then $150 might be worth it.
It is possible to do this repair yourself if you have an electronics background.
Feb 18, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from www.TvRepairKits.com. These guys rock!
Aug 19, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Green flashing crazy patterns all over
It may seem obvious, but have you may want to double-check all the connectors to make sure that none are loose?
May 15, 2009 | JVC HD-56FB97 HDTV
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
My picture is showig green,red and blue colors that can't be fixed
you need new convergence ICs. what is the model number of your set? Let me know the model number and I will be able to help you
May 09, 2008 | Televison & Video
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
Dec 31, 2007 | Televison & Video
Green and purple tv picture.
this is degaussing problem
keep tv off for half an hour and if you have changed the direction keep it as it was.
if any magnetic thing is there near to tv remove it like speaker or headphone etc.
hope this will help.
Oct 15, 2007 | Toshiba 32AF43 32" TV
Toshiba 50H81 50" Rear Projection Television Logo
746 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
