Question about Kyocera FS-4000DN Laser Printer
Kyocera FS 4000 cassette error
Error message is saying load cassette. Have made sure the cassette is fully in (till it clicks). Have removed and put back in several times.
Any ideas?
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Very helpful thanks a lot
Posted on Sep 21, 2017
  • 25 Answers
Under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
Posted on Jan 07, 2009
Error code on kyocera fs-2000 printer 7410:0588526
the error Call Service 7410:xxxxxxx usualy is about the Drum Unit not fully inserted in the printer.
On the left side of the printer you will need to open the cover and push the Drum Unit in place.
After it clicks in place power off and on the printer.
Best regards.
Oct 26, 2016 | Kyocera Developer Unit - FS-2000 3900 4000...
I have a error code 1010:0253113 can you say what this is please
Paper cassette can't be lifted.
Try to load it with less paper, pull it out and turn it upside down to see if metal plate (which lift paper) moves and check if plastic gear on side of cassette can be turned in any direction.
May 17, 2016 | Kyocera FS-4300DN Laser Printer
I have a Kyocera 4000 printer and I am getting an error message: call service 7410:0085450
Check where the waste toner bottle is, and if it's like the FS2000, the drum unit can be pushed back in from where the bottle attaches to it.
Error should then go when you close the lid back down
Feb 26, 2015 | Kyocera FS-4000DN Laser Printer
I have a Kyocera FS 6530MFP and when its in operation (during photocopying or printing), multicopies, it suddenly pops up an error on the display with the message ' cassette error ' , and abruptly sto
The cassettes have little motors on them that lift the paper up to the rollers when it's closed. Make sure there isnt a bind on the plate that lifts the paper up. If there isn't you might need a lift motor replaced. This is a pretty common issue.
www.equipmybiz.com Skelton Business Equipment Houston Copiers
Aug 05, 2014 | Kyocera Office Equipment & Supplies
How to reset a process unit
Make sure that the front and top covers close smoothly and fully. If the blue toner release arm is not fully to the rear the top cover will barely close. To reset the process unit you should remove it and then re-install it making sure it makes a good 'click' when you insert it.
Apr 15, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
I have a Canon Pixma 640. It's hardly been used since I bought it. Now suddenly there is an error message saying 'Error cassette, no paper, please load paper and press OK' I've done this...
This may sound patronising but are you sure there is paper in the cassette located at the bottom of the machine and not just on top at the back. There is also a button on the operation panel that selects which tray you are using. It could be as simple as that!!
May 26, 2011 | Office Equipment & Supplies
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Error code C70000
Hello, the code 7000 refers to the toner motor, but if you check my blog and there I have the full service manual. I hope you let me serve a Comment
http://tiototos.blogspot.com/ press click
Mar 16, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer Logo
2,325 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
George Mclaughlin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
