Question about Canon Cameras
When I switch on my camera I get 'Err CF' on the display. According to the handbook I have to format the compact flash card - when it is formatted the menu will reappear - the menu does Not reappear bu 'Err 99' does. I have been on the internet and tried remedies suggested but nothing seems to work I am just being sent round and round in circles. My camera is a Canon EOS 20D, lens is a Canon Ultrasonic 75-300mm and my card is Sandisk Ultra ll 4GB
  • 199 Answers
Things you can try:
  • clean the gold contacts of the memory card;
  • format the memory card through a computer using a memory card reader;
  • replace the memory card.
hope this helps.
Posted on Dec 16, 2008
    Genius:
  • 1,239 Answers
Hi
To clear the "Err CF" error, try performing the following procedure.  1. Try using another CF card.
If you have another CF card, try loading it in the camera.
If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera.
2. Use your computer's ScanDisk utility to check the CF card for errors.
Use ScanDisk to check the CF card for card error or card failure.
Refer to the instruction manual for your operating system or Windows Help for further instructions.
(If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.)
Be sure to back up the data on the CF card on the computer before you check the CF card.
If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card.
Follow ScanDisk's on-screen instructions to solve the problem.
If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center.
If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded.
Precautions for handling a CF card:
- Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card.
- CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration.
- Do not attempt to disassemble or alter a CF card.
- Place the CF card in the supplied case for storage.
- Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely.
- Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
  • 495 Answers
Use below link to format your card step by step
www.cs.mtu.edu/~shene/DigiCam/User-Guide/990/FIRST-STEPS/CF-format.html
Hope, it will solve your problem.
  • Manoj Rout
    Manoj Rout Dec 16, 2008
    error
    99 is usually a 'catch all' from what I know. It can be anything from a
    faulty card, to a dirty contact on your lens. I would check the
    contacts to make sure they are clean.
    If you want more info on the 'error99' I would suggest checking out
    http://www.dpreview.com
    in the 1D fourm. Just do a search.
  • Manoj Rout
    One more reason could be
    Dirty lens contacts will also cause ERR99
    The coin battery *should *be changed as well. They start out at a bit
    over 3V, and
    typical useful life in the 350D is 3 years.
    Genius:
  • 3,422 Answers
HI,
clean the CF contacts inside the camera. If it started after a few months, and formatting the CF in your camera didn't fix it, I guess it should be a faulty CF (or a faulty camera, ouch!). To double check you can borrow a CF and try it in your camera. If the latter works, then reach you re-seller or Sandisk to have the CF replaced.
  • Priya darshan Dec 16, 2008
    To isolate the cause of the issue, I suggest that you do the following:
    1. Turn off the camera.
    2. Remove the lens, battery, and CF card.
    3. Allow the camera to sit without power for approximately 20 minutes.
    4. Insert a fully charged battery, and turn on the camera.
    5. Depress the shutter button as you would to take a picture.
    Does the “ERR 99′ message appear? If it does, then the camera should be
    serviced. If it does not, then please proceed to the next set of steps:
    2. Insert the CF card.
    3. Turn on the camera.
    4. Format the CF card in the camera.
    Does the “ERR 99′ message appear? If so, then the CF card is the most
    likely source of the issue. Try using a different card.
    If the message does not appear, please complete the following steps:
    2. Clean the lens contacts by gently rubbing them with a pencil eraser
    or soft cloth. Be careful that you do not let any debris fall into the
    camera body.
    3. Reattach your lens.
    4. Turn on the camera.
    If the “ERR 99′ message only appears when one particular lens is
    attached, then that lens should be examined by a service technician.
    If you see the “ERR 99′ with a different Canon lens attached, then the
    camera should be serviced
    Also make sure that you have formatted the cf card properly:
    Please click on the below link for steps to format the card:
    http://www.cs.mtu.edu/~shene/DigiCam/Use...
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
When isert flash card i get err2 sign
According with the manual:
Err 02: There is a problem with the CF card. Do one of the following: Remove and reload the CF card, use another CF card, or format the CF card.
Try formatting the CF card in the camera, if that doesn't work use a card reader to format it in your PC then format it again in the camera. If that doesn't work try a different CF card.
Keep us updated.
Mar 22, 2011 | Canon Cameras
I have a CF err on my Canon Rebel XTI EOS
If your camera uses a compact flash card, then something is wrong with it. Possible causes: card needs formatting in camera (this will erase it) one or more pins inside camera are bent. Card was erased or formatted on computer instead of camera.
Feb 19, 2010 | Canon Rebel XTi / EOS 400D (body only)...
Hello i have a canon digital ixus v camera and i orderd a 4gb compact flash card and on the camera display it said cf error can you help
I had this exact problem. What I needed to do was first, turn on the camera with it set in the photo taking mode. Next, in the menu system, select "Format". This will format the CF card to work with the camera. Hopefully this will help!
Sep 23, 2009 | Canon PowerShot S110 / IXUS v Digital...
Err cf have changed compact flash cards. every
check deep inside the card slot to see if you have any bent pins. They can often be straightened out with a thin screwdriver.
Sep 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 5d cannot format cf care
Hi there, did you check the card itself? SD cards have a locking switch on the side. Move the switch from locked to unlocked. Put it back in the camera and see if that helps.
Rob
Mar 02, 2009 | Canon EOS-5D Digital Camera
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Canon camera has error cf
Of course you have tried to format the CF card ? That can solve the problem.
If you get err 99 when trying to format the memory card, the problem is probably in CF (Compact Flash) connector. One common reason is bent pin. You can see it when looking into card slot.
Another possibility could be the CF connector terminations inside the camera. I repaired one EOS 350D where solder joint in one of the pins (23rd) was broken. And that looked like manufacturing failure in the printed circuit board (see the picture). The solder pad for that pin was far too small. There can be also other such cases in the market. The disassembly of the camera is rather difficult but if you have some experience on that kind of work, it is worth trying when you have no other option. Some guidance for disassembly can be found for example here: http://astro.ai-software.com/articles/mod_350D/mod_350D.html
Aug 03, 2008 | Canon Digital Rebel XT / EOS 350D Body...
Cameras Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
