Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door locked light stays on so cannot open door
Machine has been drained and has not solved the problem is there a manual way of opening the door. hotpoint aquarius wd63 washer dryer
Hi I am currently having the same problem with my duet. You can try to cancel and then run the rinse and drain cycle or spin and drain cycle. Often the door will unlock after this. If not I unplug the machine for an hour and then try again. This has worked over the last couple of weeks with my washer. The repair man is coming out yet again today with a new CCU. I hope this solves the problem.
Posted on Dec 16, 2008
  • Hotpoint Master
  • 3,463 Answers
Make sure that all the water has drained or the door will not open, lay the hose into a bowl or other shallow vessel and let any remaining water run out. Wait a for a while for lock to release,if it still does not open then the door is going to have to be opened by force.
Plz rate this solution.
Thanks
  • Barry Coates
    Barry Coates Dec 17, 2008
    Make sure the dryer timer is in the completely Off position , as the door will not open if it is not.
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
SMALL LOCK APPEARS IN CONTROL BOX AND WONT ALOW
That lock icon indicates a locked door, and if you can open your door with it locked, your door lock will need to be reset. Your instruction manual should have your reset procedure listed in back. But if your door IS locked, you will need to manually drain out the water before it will open.
Mar 18, 2010 | Samsung WF328AA Front Load Washer
1998 Ford Windstar fuse problem - dome light stays on etc
you most likely have a bad door ajar switch- the door panel has to be removed to access it, its on the door latch- you can unplug them this will take care of the batt drain prob.as for the locks it may be a switch problem- most ford vehicles will not let you lock the vehicle from the driver's door when it's open to prevent locking the keys in.
May 26, 2009 | 1998 Ford Windstar
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Door locked light is staying on and door will not open
possible machine has not drained - this will prevent door opening.
put drain hose at floor level into a tray and drain that way then switch off at mains, wait 3 mins and see if door opens
Aug 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
173 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
