Question about Canon PIXMA MP530 All-In-One InkJet Printer
Check ink U071 cyan
I replace my ink catridge but it appears to check the ink U071 cyan and when i try to do printing it said more than one ink tank of the following color is installed.Cyan(8)
use one ink tank per color per time
What should i do to solve this problem and start printing again??
  • Anonymous Dec 17, 2008
    the cyan ink constantly gives a "check ink" message and will not print.  It has plenty of ink.  It has happened with new cartridges and old.  It may take one to 50 times of taking it out and putting it back, then it may work.  To say the least it is very frustrating.  I am ready to buy anther printer and this is not a year old.
  • 81 Answers
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Posted on Dec 16, 2008
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do i change ink cartridge
open the front panel just lift it u can see the catridges inside that
remove those by just pushing them downwards you can see the instructions of how to remove inside itself in a corner of your printer
try it and buy new catridge and replaceit
or else refil it with the proper advicer
thank you
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have error U071. I have been refilling the
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Feb 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
U071
Usually, it only takes on at a time. there  should only be 4 colors: Cyan, Yellow, Magenta and Black. Some printers have 8, one set is very small which is used for the printhead, but, they are still the same combo of colors. In that case is the only time you will have 2 of each color a small one for the printhead and a larger on for the actual printing.
Sep 13, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Inaccurate error message
According to Canon's website:
Details Print Friendly Version Issue: ERROR LCD: More than one ink tank of the following color is installed U071
Solution: Replace defective ink tank (MP500 / MP800)
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Aug 14, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
389 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
