Question about Stanley Bostitch MIIIFN Flooring Nailers
I AM HAVING TROUBLE OUT OF MY BOSTITCH MIIIFS FLOOR NAILER
WHEN I USE IT IT BENTS THE STAPLES. I HAVE MY AIR COMPRESSER set AT 90PSI AND ITS A NEW COMPRESSER. THE NAILERS IS ABOUT TWO YEARS OLD.
I have a stanley Bostich MlllFN Floor Nailer and Bostich air Compresser both are New . I used the staples and did over 700 square feet no problem. Started another section a week later now the staples don't go all the way through the flooring 1/4" stays up same Sub floor Need help;.
Posted on Jul 27, 2010
  • 52 Answers
D Farley,
I repair these nailers all the time. Anytime the nail or staple is bending you have 2 causes. Either the stapler has a broken blade, the magazine is loose on the foot gate, or you are shooting into plywood over concrete. that is allowing the staple to hit the cement subfloor. Use 11 /2" staples on 3/4" wood floor over 3/4" plywood when over concrete.
Posted on Jan 11, 2009
Replacing driver on MIIIFS NAILER
Must take top and bottom off tool for the driver assembly to be removed.
Apr 14, 2014 | Stanley Bostitch STB-MIIIFS Flooring...
I rented a Bostitch Floor Nailer from Home Depot, and the nails wont set into the maple flooring. Iv used three different compressors(all set to 90psi) and 4 different Bostitch Nail Guns. Im going out of...
Ive had the same problem where it was putting divits you could see from the staples, we ended up changing out the flooring completely. Only thing besides trying diff psi's to get it perfect and different length staples/different heads on staples(nails) , maybe try staple gun. Keep trying every woods different, odd that it started half way through job.. odd.
Jul 15, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
I just purchased a reconditioned MFIIIS Bostitch floor stapler. I am using 15.5 x 2" staples. The staples are not setting all the way, and are leaving about 1/8" of the crown in the groove of my...
On my floor nailer there is a white plastic pad on the very bottom that rests on the flooring. I can remove the pad and add or remove shims to adjust how deep the staples can be set. If you do not have any shimms under your pad you can get creative with making a thinner pad or ordering thinner pad (easy to make out of thin wood or plastic). Second method. Take gun apart and shave the lower bumper a little the allow the driver to set deeper. More difficult fix however works great. Order extra bumper to return to factory state. Good luck
Jul 09, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
Which nailer do i need to nail down 5/8 bamboo prefinished floor i have the basic nailer for 3/4 flooring is there an attachment to add to it
Stanley makes a foot, part number MIIIFOOT-KIT, for the MIIIFS flooring stapler that prevents scratching of prefinished floors.
Jan 20, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
I am laying 3/4 inch hickery flooring and I have an loder floor stapler. The staples are not sinking far enough into the tounge of the wood. I have tried setting my compressor all the way to 160 PSI and...
The white plastic pad at the bottom of the nailer may have a shim under it restricting the total travel of the driver. Remove bottom pad and remove shims. If no shim, you will need to be creative in making a thinner pad. Other way to set staple deeper is to shave the inner bumper a bit. This will allow the driver to travel slightly further in the cylinder. Order a new bumper to keep handy in case you need the origional thickness. Good luck
Dec 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
My Bostitch MIIIFS Floor Stapler wonk work
Sounds like you have a broken driver blade.
Sep 27, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Will not staple air coming out of frame cap ?
it's a blown seal do'es work sometime when you disconnect the airhose and reconnect?If so thats the problem
May 11, 2009 | Stanley Bostitch STB-MIIIFS Flooring...
Bostitch Flooring Stapler is making dents
Is the flooring a solid wood flooring or is it an engineered? Is the stapler an MIIIFS or a SX150 or a LHF97125? If its solid then its a square edge board nad it its not centered on the flooring properly it will dent the ens.
Feb 15, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch MIIIFN Flooring Nailers Logo
1,129 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
