Question about Samsung Refrigerators
Drinking water stopped working
Drinking water not working on frigefreezer have changed filter still no joy it just packed in yesterday the model is RS21DCSV1
    Scholar:
  • 111 Answers
Check for air leaks where the air tower enters the fresh food area. It is likely you have a poor seal and that is causing cold air to enter the FF compartment unregulated and has frozen the chilled water tank (coiled up tubing)
Posted on Dec 16, 2008
    Novelist:
  • 161 Answers
!. Turn off the water going to the Ref.
2. Disconnect the water line at the water valve on the Ref.
3. Turn the water back on long enough to fill a small glass.
4. If you have a good water supply then check the water valve on the Ref. When you press the switch in the door for water, it should send power to the water valve. If it does then water valve is bad.
What is a drinking fountain?
A drinking fountain, also called a water fountain or a bubbler, is a fountain designed to provide drinking water. It consists of a basin with either continuously running water or a tap. The drinker bends down to the stream of water and swallows water directly from the stream. Modern indoor drinking fountains may incorporate filters to remove impurities from the water and chillers to lower its temperature. Drinking fountains are usually found in public places, like schools, rest areas, libraries, and grocery stores. Many jurisdictions require drinking fountains to be wheelchair accessible (by sticking out horizontally from the wall), and to include an additional unit of a lower height for children and short adults.
Jul 03, 2013 | Water Dispensing & Filtration
Where do I put the 100 oz. Hydrastorm water bladder and route the drinking tube?
jetblackrave-
In what type of backpack are you trying to use the water bladder? The hydrastorm is most effective in a pack designed for a water bladder. A pack designed for a drinking system willhave two things: 1) a pouch on the inside of the pack that will hold the bladder in a vertical position, against the back, and 2) an opening (usually a small hole on the left/right/or on both sides). A pack without these features can work with a bladder but less effectively. Worst case, you can always make modifications to your pack to make it work with a drinking bladder.
Hope this helps.
DIYpro
Apr 28, 2011 | Blackhawk Sport & Outdoor - Others
Ge refrigerator water low, Drinking wate.
make sure line is not kinked behind the frig, maybe change filter if it has one. then change water valve if that dosent solve problem
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Sear's Kenmore Refrig is not working correctly. It is making ice cubes but there is no water coming out of the drinking spout. Strange! How do I go about fixing this problem?
in the back of the fridge there are ustally 2 water valves. one for drinking and one for ice making. make sure that they are working. also if you have a built in water filter, make sure it has been changed
Oct 15, 2009 | Kenmore 57029 Side by Side Refrigerator
Is drinking the water from the refridgerator harmful for drinking if filter is not changed?
most are just sediment filters. if water become constricted just change. no harm will come, unless you have contaminated water to start with.
Jul 26, 2009 | Amana ASD2625KE 26 Cu. Ft. Side-By-Side...
Drinking water does not work even after changing filter.
sounds like the unit has a frozen resevour in the refrigerator. you have to thaw out the tubes that leave the resevour in the refrigferator to fix.
Feb 18, 2009 | Samsung RS2534 Side by Side Refrigerator
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
183 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
