Question about Video Cameras
Playing camcorder video on TV
I have a Digilife Camcorder model HD 1080P. When i conect to the TV with AV cords or Component video cables there is no image. i can see the video on the camcorder but not on the TV
  • ron2438 Dec 04, 2009
    Can i record rca to Mini DV
Hello there. The only way to hook up your camcorder to the tv is if you change the settings of your camcorder. Every camcorder has a different setting menu so you might just have to look it up in the manual. Or maybe your cables are not connected properly.
Posted on Dec 16, 2008
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
Tip
AVCHD merging software-Join AVCHD MTS Videos for Playing on Plasma TV without...
Lossless Join/Merge Sony AVCHD MTS Videos to Play on 1080p Plasma TV <br /><br />If you have bought a Full 1080p Plasma TV, no matter Panasonic, Samsung , Vizio, Pioneer, or Sony, and got a Sony AVCHD camcorder like Sony HDR-TG5V, Sony HDR-TD10, Sony DSC-HX5V, Sony Alpha NEX-5, Sony NEX-VG10, Sony HDR-XR520V, Sony HDR-XR500V, etc with 1080p or 1080i AVCHD recording in 2011, you may like to connect your Sony Camcorder to Plasma TV for sharing precious videos at home, but before enjoying, you may like to join the related videos and create home movie for series. <br /><br />The windows version of PMB (Picture Motion Browser) for Sony camcorders doesn't work well, and there is rare satisfied <b><a href="http://sony-mts-converter.com/2011/06/lossless-joinmerge-sony-avchd-mts-videos-to-play-on-1080p-plasma-tv/">AVCHD merging software</a></b> on the market, after searched, I found a professional AVCHD Joiner, which can be used as <b><a href="http://www.aunsoft.com/final-mate/">Sony MTS Joiner for Plasma TV</a></b>. With only three steps, the videos could be combined into one single file, keeping the original 16:9 aspect ratio, video format, video codec, bitrate, etc for HD playback on Plasma TV. <br /><br />Now I will show you the quick guide to <b>join Sony AVCHD videos to play on 1080p HD Plasma TV</b>. <br /><br />Step 1. Load Sony videos to Aunsoft Final Mate. <br />Connect Sony camcorder to PC with USB 2.0 cable, or use a card reader. Run Aunsoft Final Mate on Windows XP/Vista or Windows 7. Follow camcorder wizard included in Final Mate to easily capture and download AVCHD files from camcorder to the program. Or you can click on Browser button to locate your AVCHD file path and Final Mate will automatically show all Sony AVCHD MTS/M2TS files in Resource Tab. <br /> <br />Step 2. <b><a href="http://www.aunsoft.com/final-mate/">Join AVCHD files into one movie for Plasma TV</a></b>. <br />Click the Add movie button, and a movie for lossless output will be created by default. Select the files you would like to join into one file from the Camcorder tab (imported from your camcorder) or Resource Tab (imported from your computer), drag and drop to the movie. <br /><br />Step 3. <b><a href="http://www.aunsoft.com/final-mate/">Lossless merging MTS for Plasma TV without re-encoding</a></b>. <br />Click the Export button. As there is no video for conversion, just click the OK button for lossless output. The lossless output will be finished in a few seconds or minutes. When the merging process is done, just put the videos to the Plasma HDTV SD memory card slot and enjoy the movie.
on Jun 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
What do I need to conect my CCD-TRV35E to my video player
You need RCA pins AV cable and if your video player has scart input then get scart adapter so AV cable plug in scart adapter and it will be hooked in video player.
All these info are mentioned in user manual of camcorder. Click Sony Support to download free copy of user manual and check page-7 and items 6 and 8 that needs to connect camcorder with video player.
Thanks.
Jul 14, 2010 | Sony Handycam CCD-TRV35E Camcorder
Can I get the instruction for using my Digilife DDV-330 camcorder, is there a way to down load
Hi and Welcome to fixyah,
Here check this link http://vr-zone.com/print/-digilife-all-in-one-ddv-c330-camcorder/3583.html
Mar 29, 2010 | DigiLife DDV-C330/C340 Camcorder
Do you get HD quality by outputing to TV using
no ,but you will have a dvd quality picture. HD means
the picture size format usely 16:9, HDMI its a Hd
multimedia interface its HD quality to...
hope that help you..
Feb 18, 2010 | Sony HVR-A1E HDV Digital Camcorder
HD Camcorder to Sony HDTV using Component Cables
in order to send hd video to your HDTV, you will need to use a hdmi cable. If you are planning to use component cables make sure you have component output from camcorder..still it is not HD.
Dec 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
What kind of A/V cable comes with the Aiptek A-HD 1080p camcorder, composite or component?
Never mind. The camera came with both composite and component cables.
Aug 03, 2009 | Aiptek Video Cameras
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
Playing tape on TV?
camcorders have component or hdmi or Svideo port check that whitch one is on your TV and cam,them connect them; put yor tv on AV channel and camcorder on Play mode. I hope this helps...
Nov 01, 2008 | Sharp VL-Z5 Mini DV Digital Camcorder
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
175 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
