Question about Whirlpool Washing Machines
I have whirlpool awm 5145 the counter turnsbut nothing happens
    Novelist:
  • 161 Answers
Check the lid switch. There should be a small pin on the lid that will push the lid switch down when it is closed. There are two wires going to the lid switch, jump these two wires together and if it works then replace the switch.
Unplug the washer before doing any work.
Posted on Dec 16, 2008
Bearings for a AWM 5145
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Sep 04, 2012 | Whirlpool Washing Machines
My awm 5145/4 has stopped working! There is still power going to it but when you select a programme it does nothing,but it will drain,someone has suggested the brushes,where are these located on this...
Could well be the Carbon Motor brushes that are worn they last round 5 years hen need replaced..I lie under the machine to do this but you may find it simpler to remove the motor they are located at the side and are secured by two screws, parts cost around £25 per set.....
Feb 27, 2011 | Whirlpool AWM5125/1 Front Load Washer
How do i open the filter cover for my whirlpool awm 5145/3 washing machine?
Tip is back a hair and remove the screws and bottom panel then grab the cap045bec0.jpg7d5c207.jpg
Mar 13, 2010 | Whirlpool Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Awm 5145
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Jun 24, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
145 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
