Question about Kenmore 20722
Kenmore 20722 won't spin
Thanks, Profane, for the quick and helpful response. Maybe I will get this thing repaired. I looked through the parts list in the original documentation, but I do not see the part number, or anything named motor coupler. Any more help will be much appreciated.
  • 67 Answers
285753a is the part number for the motor coupler no problem hope it helps
Posted on Mar 21, 2007
Drum out of balance after repair on 20722 kenmore washer
THESE WASHERS SIT ON A SKATE PLATE PICK UP ON THE TUB A TURN IT A BIT AND TRY IT ONCE IT IS BACK ON THE SKATE PLATE WILL OPERATE PROPERLY
Apr 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 20722 Series 70 top loader. Makes a load, intermittent banging noise as the tub attempts to spin. The tub seems to engage intermittently, too.
Check the vibration dampers are solid and the mounts good. Also the springs on the bottom of the drum.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore 20722
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Kenmore washer not spinning or agitating
hi thanks for the question don't take back off please. the problem is with the motor coupling located at the motor & transmission to repair . 2 screws at console .remove .lift console .remove 2 brass clips disconnect wiring plastic disconnect pull cabinet towards you .put a block under left front lift up remove the pump 2 spring clips .remove motor wireing . remove the motor replace the motor coupling thanks the appliance doc
Sep 06, 2008 | Kenmore 20722
Won't spin
hi thanks for the question the problem you are having is with the clutch located on the transmission replace the clutch
Jan 19, 2008 | Kenmore 20722
Kenmore 20722 Motor Coupler or Cluch assembly?
Its easy to check the coupler, i would do that first to make sure then if its ok , well clutch. Kenmores, a.k.a. whirlpool's , are very common to have both problems. Just remove da pump and hoses, then remove the motor and check the coupler.
Sep 21, 2007 | Kenmore 20722
Kenmore - tub does not spin
motor coupler 20 bucks from the repair store 285753a is the part number i believe gl
Mar 21, 2007 | Kenmore 20722
Washing Machines Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
