Question about Sanyo S750 Cellular Phone
APPLICATION INSTALLATION PROBLEM SANYO S750i
HI,
I HAVE SANYO S750i, I WANT TO KNOW THE WAY TO INSTALL THE APPLICATIONS.
THANKS
IRFAN CHATTHA
    Problem Solver:
  • 5 Answers
Hi
The only way to install applications on this phone is via WAP, you can download .jar and .jad files to the phone this way.
You CANNOT copy them over using a cable, on the memory card or bluetooth, it does not work.
Posted on Mar 09, 2009
I want to disconnect/remove an external GE water filter for a refrigerator from the copper lines that go in and out of the filter. They were pushed in place to install, but how do I get them out?
Install applicationsYou can transfer installation files to your device from a compatible computer,download them during browsing, or receive them in a multimedia message, as anOther applications© 2010 Nokia. All rights reserved.106
e-mail attachment, or using other connectivity methods, such as Bluetoothconnectivity.
You can use Nokia Application Installer in Nokia Ovi Suite to install an applicationto your device.
Icons in Application manager indicate the following:SIS or SISX applicationJava applicationwidgetsapplication installed on the memory cardImportant:Only install and use applications and other software from trustedsources, such as applications that are Symbian Signed or have passed the JavaVerified™ testing.
Before installation, note the following:
? To view the application type, version number, and the supplier or manufacturerof the application, selectOptions>View details.
To view the security certificate details of the application, selectDetails:>Certificates:>View details. Control the use of digital certificates in Certificatemanagement.? If you install a file that contains an update or repair to an existing application,you can only restore the original application if you have the original installationfile or a full backup copy of the removed software package. To restore the originalapplication, remove the application, and install the application again from theoriginal installation file or the backup copy.
The JAR file is required for installing Java applications. If it is missing, the devicemay ask you to download it. If there is no access point defined for the application,you are asked to select one.Other applications© 2010 Nokia. All rights reserved.107
To install an application, do the following:
1. To locate an installation file, selectMenu>SettingsandApplication mgr..Alternatively, search installation files using File manager, or selectMessaging>Inbox, and open a message that contains an installation file.2. In Application manager, selectOptions>Install. In other applications, selectthe installation file to start the installation.
During installation, the device shows information about the progress of theinstallation. If you install an application without a digital signature orcertification, the device displays a warning. Continue installation only if you aresure of the origin and contents of the application.To start an installed application, locate the application in the menu, and select theapplication. If the application does not have a default folder defined, it is installedin the Installed apps. folder in the main menu.
To see which software packages are installed or removed and when, selectOptions>View log.Important:Your device can only support one antivirus application. Havingmore than one application with antivirus functionality could affect performanceand operation or cause the device to stop functioning.
After you install applications to a compatible memory card, installation files(.sis, .sisx) remain in the device memory. The files may use large amounts of memoryand prevent you from storing other files. To maintain sufficient memory, use NokiaOvi Suite to back up installation files to a compatible PC, then use the file managerto remove the installation files from the device memory. If the .sis file is a messageattachment, delete the message from the Messaging inbox.
May 07, 2018 | GE Refrigerators
How to install softwares on htc wildfire
If you have application files (*.apk) on your computer, you can use HTC Sync to install them to HTC Wildfire S. It is strongly recommended you install only applications that you trust.
Before you begin, make sure that HTC Wildfire S is set to allow applications from your computer to be installed toHTC Wildfire S. To do this, press howtoimage.aspx?id=88185 while on the Home screen, tap Settings > Applications, and then select the Unknown sources check box.
  1. On the Device panel, click Overview.
  2. Click Application installer.
  3. Browse for the application file on your computer, and then click Open. The installation process starts on HTC Wildfire S.
  4. Check the screen on HTC Wildfire S to see if there are additional instructions to complete the installation.
  5. After installation is complete, you can click Disconnect.
  6. Safely remove HTC Wildfire S as required by your computer's operating system.
Jun 01, 2012 | HTC Wildfire
When I download a jar file it automatically gets install through (JBlend) but when it finishes installation it gives notification
The jar file might be corrupted, try to download the jar file from a reliable source.
Hope this helps, thanks for using fixya!
Nov 14, 2011 | Cell Phones
I upgraded the Android system for my sanyo zio and now i can't recieve any text messeges cause it says that the memory is full and it also says that my phone memory is full eventhough iv'e been erasing...
It seems most of you applications are stored in the Phone Memory and/or your application data is taking up lot of memory. You actually don't have to erase/uninstall applications. Please consider performing the following steps:
  1. Go to Settings --> Applications --> Manage Applications. In this Menu you'll be shown a list of applications. Use the Menu Button to "Sort by Size" and get a list of the applications sorted from high memory usage to low (phone memory). Once this is done, you'll be able to view the memory being used by each of the applications. Click on the applications which you see are consuming more memory and then use the "Clear Data" button to clean up the data being stored by the applications to free up memory. This clears up any cache, cookie, temp files associated with the applications. Depending on your android version, you may also see an additional button "Move to SD Card". The best option to get more space would be to use this button and move the application to the 4 GB SD Card storage.
  2. Optional Step if you do not have "Move to Phone/SD Card" option available - From the Android Market, download and install "App 2 SD Free". Once done, this application should help you free up a lot of space by moving applications from your phone memory to the SD card.
Hope this was helpful. If so, please consider rating this solution.
-thanks,
M
Mar 09, 2011 | Computers & Internet
How to install a third party application on my galaxy 5 gt-I5503 phone in order for me to have a MP4 and other applications..
There is an option to "Allow installation of non-Market applications" at Settings->Applications. Try to mark it "checked", and try again if your third party app installs.
Feb 06, 2011 | Cell Phones
SONY VAIO VGN-CR520D MY PROBLEM IS WITH MY WEB CAM, NO WORK WITH WIN7
Hi carlosoaj,
You need to re-install the Camera Driver after the installation of the Windows 7 Operating System in the computer. As the Windows Vista Drivers are compatible with Windows 7 Operating System, you can try installing those Driver.
Please download the Camera Driver here
Please download the file to a folder in the Computer. Then, please open the folder where the files is downloaded and double click on it to begin the installation. Please follow the onscreen instructions to complete the installation process. After installation, restart the Computer for the settings to take the effect.
After that, install the Windows 7 Camera Applications in the Computer. You can download the Windows 7 Camera Applications from the below link.
WebCam Companion Software
Magic-i Visual Effects Software
Please download and install the Software in the computer. Make sure that you restart the Computer after each installation for the settings to take the effect. Then, please click "Start", "All Programs" and click the "WebCam Companion" to open the Camera Application and use the Camera.
Hope this helps...
Good Luck!!
Jun 01, 2010 | Sony VGN-CR520E/J VAIO Notebook
Problem with samsung j700
Hi,it seems you have problems with the installation of games and applications on your phone,
Here is the solution;
The best and only way to install games and applications on your phone is through downloading from the internet
The samsung J700 supports only java enabled games and applications,
so be mindful of the games and applications you download because if youdownload a game or application of another format,it will not functionproperly or not at all,and may pose a risk to your phone.
You can get cool applications and games for free at this website;www.sharemobile.com
Take care
Mar 10, 2010 | Samsung J700 Cellular Phone
Fm application for my mobile
hi,
connect the phone to your pc with nokia PC suite installed in your PC.
then go to install applications and then install your application
thanks you
Feb 08, 2009 | Nokia 7610
I recently bought a 1GB card for my S750iand the phone does not read it...
For the MaxMan123, Sanyo s750i did'nt support the 1GB Memory Card. Please use 512MB Memory Card
Nov 10, 2007 | Sanyo S750i Cellular Phone
Sanyo S750 Cellular Phone Logo
Top Sanyo Cell Phones Experts
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
