Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
I would love to get directions to installing the top and bottom cam to my 550 Sub zero
Http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code is the locator area parts distributors. Once you get the parts in, remove everything from the door, food, shelves.... Then with the door closed remove the upper hinge. If you have a left hinge unit you can bend the shroud out of the way and bend it back when you are done. The door can be quite heavy if you have wood panels on it so you may need help. Open the door 90 degrees and lift up and over the bottom hinge. Remove the cam from the door using a phillips head screw. Then replace the hinge cam that is on the hinge that is still attached to the body. Now you will need help, lift the door up and have some one set it into the lower hinge pin. Close the door and have some one hold it closed while you climb up and reinstall the hinge. You may have to adjust the door by sliding it forward and back left and right until you get your sight line just right.
Posted on Dec 16, 2008
Sep 13, 2014 | Sub-Zero 695/S Side by Side Refrigerator
Sep 01, 2014 | Sub-Zero 632 / S
Jan 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
Jun 29, 2010 | Sub-Zero Bottom Freezer Refrigerator
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Jun 27, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Nov 01, 2007 | Sub-Zero 650 / O Bottom Freezer...
2,534 people viewed this question
