Question about Nikon Cameras
My Nikon Coolpix 8800 works fine until you take a picture, then it comes up with System Error 2 and locks up. Switching Off and On again clears it, but I have no manual or CD as I bought it Second hand, So as yet I have not been able to connect it to my computer and down load images. Are these two things related? Paul Cantley
  • 199 Answers
Temporary solution from here:
  1. Rotate the control dial on the top of the camera to the SET UP position.
  2. Cycle through the menu options down to where you see "reset camera"
  3. It will erase all your settings,
  4. Select "yes"
hope this helps.
Posted on Dec 16, 2008
  • 470 Answers
You need to reprogram it, because the system error 2 can only be fixed by reprogram it,, but a usb hud or usb wire to connect it from computer, then "right click", and clik "reformat"
    Master:
  • 763 Answers
Sir, if your going to transfer pictures on your computer you should use USB cable that would fit on your camera and your computer. its not that hard to find it on some eletronic or camera shop. Once you have it you can transfer it without any problem.
http://www.starbatteries.com/nico88dicaow.html
heres the manual for your camera. just click the download and be sure you have pdf reader to be able to read this on your computer.
if your camera wasnt able to read on your computer after inserting the USB then you should the download the driver below this message and install it on your computer. it should be working after you install it. hope that helps
http://www.driverfiles.net/Cameras/Nikon/COOLPIX-8800/download/page,sh,24592,3,17,.html
thank you for using fixya
CHARCOIS
    President:
  • 2,110 Answers
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card)
  2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Problem with the Nikon Coolpix 8800 Digital Camera System error 2
my Nikon 8800 vr cool pics will not turn on with a new battery but will work on ac
Aug 02, 2011 | Nikon Coolpix 8800 Digital Camera
When I shot each photo, the "system error 2" appears and I have to turn off the camara,
System Error 2 on Nikon Coolpix 8800 is usually after blow, even the small one, when you or somebody kick the camera and yes, FULL RESET on Set Up mode is just one solution. It's camera's error not the card.
From Nikon website:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Good luck.
Jun 03, 2011 | Nikon Coolpix 8800 Digital Camera
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
I got message "system error
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
I have a nikon coolpix 8800. i have a 6gb card installed. I have the latest firmware. I recently took over 1000 pictures on a trip without downloading any of the photos. Once the picture count got over...
Try this...go into the menu and try to find an entry for "reset" to get back to factory default settings. Then, assuming you've safely downloaded any pics from the card, insert it into the camera, go into the menu and find "format"....follow the on-screen instructions to erase and optimize the card. Let me know how this works for you.
Nov 16, 2010 | Nikon Coolpix 8800 Digital Camera
SYSTEM ERROR 2
Hi and welcome to Fixyah,
System error 2 comes out when it was happen? when trying to install the software comes with it or when trying to get shot?
Aug 10, 2010 | Nikon Coolpix 8800 Digital Camera
I have a Nikon Coolpix 8800 with a "System Error 2"
Check the memory card. It's probably damaged. If not it should be a software error, and you have to take it to the dealer where you purchased it from
Apr 06, 2010 | Nikon Coolpix 8800 Digital Camera
Memory card
Hi Janet, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Jan 02, 2009 | Nikon Coolpix 8800 Digital Camera
System error 2
The SYSTEM ERROR 2 problem that is occuring with your camera could be the memory card. Also try cleaning the connections
Dec 18, 2007 | Nikon Coolpix 8800 Digital Camera
Cameras Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
