Question about Brother MFC 210C All-In-One InkJet Printer
BROTHER DCP-135C all in one inket printer cyan comes out green ??
Brand new printer was fine on original cartridges they ran out and put compatible set ...all colours are fine apart from cyan ...initialy 1st one used was blank in spite of numerous head cleaning ...changed it for another new one , now coming out as green ..other colours from same replacement batch are ok ...satus monitor reads everything is fine ...connection to laptop is ok ..I have deleted software and re installed it ..to no avail ...????
  • Anonymous Feb 08, 2009
    I replace compatible ink catridge after , 3 coloured one. it was working fine untill i replace the balck one with another compatible one.
    Then the pink and black catridges cannot be seen on printing and makes printing yellowish green. Tried clean function several times but still the same.
    Problem. How to solve ?
    The printer is les then a year old only. :(
    Model DCP135C
Mix-it-up
  • 832 Answers
SOURCE: dcp 135c
unplug from power. wait 2 minutes. take all carts out. refill to full. plug to power and wait til machine demands carts. insert cart one after another and give answer to display in case there is a message.
Posted on Jun 23, 2008
yooperbud
  • 8637 Answers
SOURCE: Can't install DCP-135C drivers WinXP
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
devdeep545
  • 137 Answers
SOURCE: DCP 135C won't print in black
This is a generic problem for many printers. Some printers print black by 4 catridges. Try this, or it will be better that you call service support.
Posted on Aug 12, 2009
  • 526 Answers
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Posted on Dec 19, 2009
SOURCE: BROTHER PRINTER DCP-135C INSTALLATION
i got disk if u want i can uplod disk and u can download
Posted on Jan 29, 2010
Printer will not print cyan
Genuine ink cartridges are expensive but sometimes the off brands don't work. If you're using generic ink try switching it out with brand name. The ink also has a tendency to clog if you haven't printed anything in a little bit. Use a q-tip and alcohol to clean around the ink cartridge in the carriage, etc. then try again.
Mar 02, 2010 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP-135C won't print yellow
1 years?
Means still under warranty for print head. maybe print head faulty. Better send to Brother.
Jan 27, 2010 | Brother DCP-135C Flatbed Digital MFC...
I cant get the black print,after putting a black cartridge in,can you help please...brother 135c
Dear sir.
If your black cartridge is original
then it is problem printer black ink head
change it and buy a new one
Thanks
Tareq
Aug 26, 2009 | Brother DCP-135C Flatbed Digital MFC...
I could not install my Brother DCP-135C MFL-Pro Installation. Because it could not detect USB cable. Please help.
It sounds like you may have plugged it in too early in the installation. Try uninstalling it and completely re-install, but don't connect the usb cable until the installation software tells you.
May 13, 2009 | Brother DCP 130C All-In-One InkJet Printer
I changed my cyan ink
That definitely sounds like the cartridge isn't registering properly. I would take the cartridge back to where you bought it and ask them to exchange it with a new one. This can happen from time to time.
If the printer was new out of the box, contact the manufacturer for a replacement cartridge. You can reach Brother here
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
9:00am to 8:00pm Eastern Time
Apr 28, 2009 | Brother DCP 130C All-In-One InkJet Printer
I have a brother 115c, have installed a new cartridge in cyan, now it says there is no cartridge there, is there anyway i can get it to register the new cartridge?
My Brother DCP-115C I have replaced colours Cyan and Magenta both colours still will not print. Ihave gone through the cleaning procedures still will not print these colours
Jan 19, 2009 | Brother DCP 115C All-In-One InkJet Printer
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
Jan 17, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-135C Printer
How to refill the Brother DCP 135C cartridge
Oct 07, 2008 | Office Equipment & Supplies
Dcp 135c
Jun 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
