Question about Quinny ZAPP Stroller
Fracture around rear wheel bearing between wheel and stub axle. Require new wheel urgently.
Purchased a new wheel on ebay
Posted on Dec 17, 2008
How to change rear wheel bearing 2005 mazda tribute
by look of the size of the vehicle
and the rear bearing shows up as a solid
if into a lower control arm
a special tool to press out the solid bearing with control arm on the vehicle
or
rear stub axle off the vehicle and press out the old bearing
press in the new
Mar 05, 2017 | Mazda Cars & Trucks
1952 chevy truck king pins install
Remove the road wheels, remove front hub from stub axles, remove the cotter pin nut and drive out the pin, remove the welch plug on the top of the king pin and with a drift drive the pin through the axle, press the old bushes from the stub axle and press in new bushes, ream the bushes till the king pin will just slide in .Then assemble make sure there is no play between the pivot bearing and stub axle use shims if required.
Sep 24, 2014 | Cars & Trucks
On a 2002 Lincoln LS ..... I ahve a rear axle bearing noise. Is it necessary to open the "pumpkin" to release the axle from inside the axle or is there a bolted flange retainer behind the rear...
Hello lemofla: My name is Roger and I will help with your question. It is not necessary to remove the rear axle from the differential in order to replace the wheel bearing. This operation does require some special tools and alignment of the car to complete the job. You will need to remove the nut on the axle stub at the rear wheel hub. The rear brakes and spindle unit must be removed. The splash shield rivets must be drilled out so the shield is not damaged. You will need a press and snap ring pliers in order to remove the bearing hub from the old bearing. Once the hub is removed you will need to press the bearing out of the spindle.When all is reassembled the dust shield should be reattached with new aluminum rivets. Reinstall the spindle and brakes. Torque the axle nut to 221 (ft.lb.). It may also be necessary to push the axle shaft stub out of the hub with a puller as the axle can be stuck. As you can tell this is not a quick fix and does take special equipment. So if you do this yourself PLEASE be careful and pay close attention to the way things came apart and be sure to have the car realigned. Should you not realign the car it will not drive right and you will prematurely destroy the tire on the side worked on. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Mar 29, 2011 | Lincoln LS Cars & Trucks
Front axle removal
remove the axle stub retaining nut, disconnect the lower ball joint, disconnect the tie rod end, pull the spindle out and away from the axle stub tapping on the end of the stub if necessary with a hammer (just be careful) to pull the bearing hub loose from the axle stub. after separating the outside slide under vehicle (make sure the car is on jack stands and the rear wheels are blocked from rolling and very secure before crawling under any vehicle) look at where the inside axle stub goes into the transmission. you'll need a good sized pry bar to pop the axle out of the transmission. work the pry bar in between the inside axle stub and a good thick part of the transmission and pry the axle away from the trans., there is a snap ring on the inside axle stub that internally retains the axle you have to pry hard enough to compress the snap ring into the axle groove which will release the axle for removal. it's not a bad idea to replace the axle seal in the transmission while you're there but if it's not leaking and you don't damage it in the removal of the axle it's not necessary. measure and compare the new axle to the old one, it may have some differences in the shaft like missing vibration dampeners but if it's the same length and both axle stubs match the old ones in size and number of teeth you should be good. when you install the new axle line it up by hand and slide it in as far as possible manually then tap it in with a wooden or rubber mallet. if you don't have a mallet use a scrap of wood to protect the new axle stub threads and tap it in with a hammer. after you feel the snap ring collapse and the axle slide in tap on it gently to make sure it's fully seated then grab the inner axle stub and tug on it to insure the snap ring is in place. then reassemble in reverse order of removal making sure all nuts and bolts are tightened properly and all retainers are in place. good luck
Jan 06, 2011 | 1997 Chrysler Concorde
Can you please tell me how to change the rear wheel bearings on a 1999 Vauxhall corsa van. The make and model is not correct it didnt have Vauxhall to choose from. Thank you Rob
yes sorry but you know the americans ,they dont do geography and they beleave in flat earth theory ,lose sight of land and the world stops ,yes easy job they are taper bearings on vehicle of this age and easy to change ,hardest part is knocking the bearing paths out ,when i service vehicles and i always take the back drums off to clean and inspect and adjust the auto brake adjuster i always put some engine oil in the dust cap before i refit to keep the grease soft ,anyway dont you know this is a opel not a vauhall -GB doesnt exist anymore across the channel but its a third world religious ethnic state of mohamed .
Jan 03, 2011 | Volkswagen Corrado Cars & Trucks
How to change wheel bearings on jaguar xj6 front 1996
Disconnect the vehicle battery ground lead.
Support the vehicle at the front and remove the appropriate wheel.
Remove brake caliper and disc assemblies see SRO 70 10
Note- Do not allow the caliper to hang by either harness or
flexible hose.
Pry off the hub grease cap
Remove and discard cotter pin
pull off castellated nut retainer
Remove the hub nut and bearing washer.
Carefully remove the hub assembly from the stub axle.
Pry the original seal from the spigot and discard.
remove the bearings and using a drift punch knock out the bearing cups.
Remove all traces of grease and dirt from the stub axle and back plate.
Note: the backing plate may be used to pull the inner bearing and seal if they stay on the stub shaft.
Press in the new bearing cups using a socket or other tool of the correct size to prevent damaging the new bearing cup or hub.
Note: Do not use bearing to press in the cup.
Pack the annular gaps of the oil seal lips with grease.
Wash the hub assembly thoroughly.
Ensure that the hub inner seal diameter is free of debris or damage and is lightly lubricated prior to assembly.
Only replace complete bearings, never cup or race in isolation.
Pack each race with approximately 4 ml of grease and position the inner race onto the stub axle.
Apply a smear of grease to hub inner surfaces and bearing cups. Assemble the hub to the stub axle followed by outer race, bearing washer and hub nut.
It is not necessary to fill the hub cavity with grease, merely protect from corrosion with a coat of lubricant. Seat the bearings by slightly tightening the hub nut whilst rotating the hub. Do not apply load without rotation.
Adjust End float. Set a Dial Test Indicator and adjust the hub nut to achieve the correct end float.
.001-.003"
As the adjustment is made, continually load the hub axially in both directions.
Without disturbing the end float setting, fit the castellated
nut retainer so that it aligns with both hub nut and stub axle drilling.
Secure nut retainer using a new cotter pin.
Reassemble brake rotor and caliper. Bolts MUST be tightened to specification
operation of the braking system verified.
Reassemble wheel
Dec 25, 2010 | 1996 Jaguar Xj Series
Wheel bearing
the rear bearing is pressed into the hub so take the hubs off and take to a engineering shop to have the new one pressed in ,now the front ones are similar in as much as they need pressing in and out ,DO NOT TRY TO DO IT WITH A BIG HAMMER ,its dangerous ,remove the wheel trim and slacken the big nut in the middle ,think its a 32mm then jack vehicle up remove the wheel ,undo the brake caliper by the 2 bolts that hold it to the stub axle ,slacken bolt on track rod end but do not remove fully and then wack the end of the stub axle where the track rod end goes through .One good wack with a 1kg hammer will do it on the end of the steering /stub axle shaft without damaging anything because you have left the nut on loose.then remove the bottom track control arm pinch bolt it has a star head and a 17 mm nut on the other end ,use a lengh of scaffold pole or a big crow bar to pull the track control arm down so the ball joint come apart ,take the stub axle off and in the back is a big circlip but leave it alone and just take it to the engineering shop ,its very dangerous to try to remove the bearing with a big hammer and drift because it can and will chip and hit you in the face trust me on this
May 27, 2010 | 2007 Ford Focus (3 Door) Hatchback
I am to replace rear stub axle on a seat ibiza? do i have to strip out the inside of the drum before removing the old stub axle?
The simple answer is YES. You will need to remove brake drum / hub and inner and outer wheel bearings. This allows access to the retaining bolts.
Although a little tricky___You should now be able to install a new stub axle, without removing the brake shoes or Handbrake cable
John
Jan 20, 2010 | 2000 Volkswagen GTI
How to change rear bearing mk 2 golf
If I'm not mistaken it's a 30mm
Feb 20, 2009 | 2000 Volkswagen Golf
Quinny ZAPP Stroller Logo
96 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
