Question about Texas Instruments TI-30XA Calculator
I don;t undersdtand what x bar is - Texas Instruments TI-30XA Calculator
  • 43 Answers
"x bar" returns the mean of a series of numbers entered in "statistical mode".
e.g.enter 3, then press the "sigma plus" key (just above the "STO" key. Display will show "n = 1" and "STAT" will display to remind you that you are in statistical mode.
Enter 3 the "sigma plus" and you will see "n = 2" to tell you that you have entered two numbers. Keep doing this for a few more, then press "2nd x bar" and you will see the mean of all the numbers you entered, which is 3 if you entered all 3's.
To exit "STAT" mode, you have to press "2nd" then "CSR" (just above the 7 key), since the regular "clear" key only clears the pending entry.
Lots of simple statistical stuff you can do on the TI-30XA, read the guide book, available online at TI if you don't have one
Posted on Dec 31, 2008
Center bar heat
what procedure of replace piston/rings
Feb 07, 2014 | Hyosung Motorcycles
If I order the sissy bar back rest for my 1985 Yamaha V-Max how do I instal it. It looks like a two piece set up but don't know. Will I have to drill holes or modify my bike to instal the sissy bar?
Presuming that the cissy bar is designed for the bike, there is no need to drill holes. There is a chrome curve mounted on the rear mudguard by two allen bolts. You remove the two bolts and depending on the make of the cissy bar you have simply use the bolts to fix the cissy bar over the top of the original chrome.
There are dozens of cissy bars from various aftermarket manufacturers, so it's hard to be precise. Some come with a spacer that fits into the recess on the chrome curve to hold the side of the mounting away from the chrome, some don't. Some come with extended bolts for you to use, some don't. All in all however it's a very simple and fairly intuitive bit of kit and should only take you about 15 minutes to bolt up.
If you would like to drop a comment on this thread with the make and model of the item you plan to buy, and if you have it, a link to the item so that I can take a look at it, I'll give you some more information about fitting, but you really shouldn't need any. It really is an easy job
Sep 21, 2011 | Yamaha V-Max Motorcycles
Call barring has been activated i dont know what is the barring password
Call Barring is a network feature. The Password for this feature is set by network. So don't need to worry. Just call your Network Service providers and ask them for the code, they will first authenticate you and will give you your code in return.
Note: Don't get spammed by someone telling you he can give you the code.
Regards, Wiqi
Aug 11, 2011 | Nokia 1100
I don't know what caused it, but my start menu, desktop and taskbar don't appear anymore after bootup. They appear only in safe mode. I've run antiviruses including the latest Dr Web CureIt and...
Hello it could either be that you have shortened the task bar or its on auto hidden type CTRL + ESC that will bring up the start/task bar right click the task bar and check the settings make sure that auto hide is turned off and that the task bar is unlocked and resize it if you can.
Hope this helps.
Jul 16, 2011 | Computers & Internet
The steering bar is not even with handle bar. The child's handle bar is straight, but the push bar will then be crooked to the right.
I put some packing tape around the bar to where the handle bar fits. It is holding for now, i don't know how long it would stay :)
Jul 11, 2011 | Radio Flyer Steer and Stroll Deluxe Trike
I feel like I'm missing something. I can not attach the handlebars to the bike. I have one long screw, a bolt and some small black cylinder cut on an angle. The instructions are not helpful because...
the cylinder cut on an angle is what the long bolt should bolt to, put the cylinder below the handle bars, and drop the long nut down through the handle bars and into the cylinder, ( the hole in it should be threaded,) only start the bolt so it hangs onto the cylinder, then feed that into the top of the neck hole, where the handle bars slide into,, once the desired height is ok,, tighten that bolt, the cylinder will come up at an angle and tighten the neck and handle bars !! Good Luck
Jul 02, 2011 | Dynacraft Girls 16" Barbie Bike
Am looking at your 4 bike hitch rack. Need to kow if it will hold a woman's style bike? One that does not have the top cross bar.
WE don't see what you're disussing and WE don't market anything. We advise.
To your question: they make adapters for non-standard bike frames like the so-called women's style to provide a 'top tube' for hanging on a bike carrier.
Google "bicycle adapter bar" or look on eBay.
For example... http://cgi.ebay.com/Allen-Tension-Bar-Bicycle-Cross-Bar-Adaptor-BLACK-900B-/220782155858?pt=Cycling_Parts_Accessories&hash=item3367a45852
May 22, 2011 | Cycling
I am typing the code of barring 1234 ,but the phone answer not complete
don try that it wont work call barring facility is provide by the service provider it has no default password. Also no call barring facility is available in many of the networks
Mar 18, 2011 | Nokia C3 Cell Phone
Texas Instruments TI-30XA Calculator Logo
141 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
