Question about Samsung SC-D353 Mini DV Digital Camcorder
Compatability with Vista
Is scd353 compatible with Vista. What else must I do to make the device work with the computer. The problem is I can't connect the digital camcorder to my computer.
  • Anonymous Apr 23, 2009
    I also used ulead video studio but version 11 and when i capture video i can save it to a file from the tape but no audio is heard. only video.
I use mine in Vista with USB cable, Samsung Vista driver which works in Device Manager, but not Windows Vista Scanners and Cameras. I loaded ULead 6.0 which comes with the camera, and have no problems. This is not the way I want it to work, but it does allow me to use my camera. I would much rather Capture to Microsoft Windows Movie Maker. I do love this camera, seems they are still selling them, so hopefully Samsung with fix the driver. Microsoft lists it as Microsoft Certified Compatible? Not quite.
Posted on Jul 14, 2008
You shouldn't need drivers, it should work with Windows Movie Maker automatically but i've found that this camera DOES NOT TRANSFER VIDEO WITH A USB cable, regardless of what every BestBuy employee tells you. The USB only transfers still pictures from the memory card. The instruction manual is not definitive on this, but most cameras that are MiniDV that have both USB and IEEE1394 ports like this one operate similarly. Get a firewire cable and a firewire card on your pc and you'll be fine. If you use a MAC, quicktime pro and imovie will also transfer videos using only a firewire connection. i know...it's really lame, but lots of cameras that have both usb and 1394 ports on them work this way.
Posted on Dec 01, 2007
Yes, Samsung have drivers for win vista, but before install drivers, the Win Vista not detect camcorder. :-(
Posted on Nov 21, 2007
    President:
  • 3,130 Answers
You will need to contact the camcorder company and see if they have an up date for the Vista compadability as this is a problem with alot of devices since microsoft pulled this stinker of a program on us. Good luck
Posted on Mar 21, 2007
SOURCE:
Pic wont come up on my laptop
hi,
try running in compatability mode as some sat navs software still only work properly with windows vista sp1.to do this right click on programe shortcut select compatability re-start pc after instal all should be well. good luck
Mar 22, 2014 | Garmin nuvi 205 GPS Receiver
I have samsung sch w 299. When i tried installing the software for this phone on my computer it said that the software is not compatible with os... i am using windows vista
If you cant find the driver for vista you can try to install the software in compatability mode.
Right click on the program and choose to run in compatability mode.
This works sometimes
Jul 07, 2010 | Computers & Internet
Compatability
check with sony
Aug 28, 2017 | Sony Cameras
Install problem
Run the Setup.exe file in compatability mode (right-click the setup.exe icon and select properties, then select compatability and choose a 32 bit version of XP). The game was not tested on 64-bit Vista and isn't likely to work outside of 32 bit compatability mode.
Feb 13, 2009 | Command Conquer 3: Kane's Wrath for...
Bluetooth compatability problem
Try downloading updated drivers for your BT device. Then, try uninstalling and reinstalling the device with the updated drivers.
Nov 13, 2008 | Microsoft Windows Vista Home Premium with...
Sims complete collection won't run on my windows vista
Hello.. The Sims collection does have some compatability issues with vista but EA has worked on it and actually it should run fine.May be any running process is conflicting with the game or you may have to update your Display drivers.
Also try using the compatability mode.Just right click on the game *.exe and select properties.then select the compatability tab and check the box "run in compatability with Win Xp[sp2]".
In adition you can check for any available patches here. http://www.electronicarts.in/search/?search=sims
Oct 30, 2008 | EA - Electronic Arts Sims: Complete...
HP PSC 2350 Printer/Scanner & just purchased a new computer (Windows Vista) & the discs I have for this printer/scanner only support Windows 2000, XP not Vista.
You can set compatability to windows 2000. I presume you have vista. start menu. control panel, programs... then you will see set compatability or similiar (my control panel won't open at the moment). use the wizard to walk you thru the steps. select the program you are having issues with. It will allow you to run the program as win 2000 compatability.
Robert
Aug 27, 2008 | HP Office Equipment & Supplies
I cannot get my Maxell ballcam to work with Vista
Remove software and see if Vista will see it on its own.
This is a compatability problem
Reinstall softwarte and go to Start/Programs/accessories/system tools/compatability Wizard/ reset the computer to XP or 98
Jul 21, 2008 | Cameras
I have just installed a new computer with Windows Vista. I am getting an advisory that there are compatability problems with Vista and the Canon iP1700 printer. C an you advise?
There are several things you can try if you have a device that is not working correctly:.
Please check this link. You will find the driver for vista
DRIVER
• Check if updated drivers are available through Windows Update. When you check Windows Update, click View available updates to determine if an updated driver is available for your device. For more information, see Install Windows updates.
• Make sure that the hardware device is compatible with your computer and with your version of Windows. If the device is not compatible, you will need to find the correct driver. Check the information that came with your device. You can also search for the device on the Windows Vista Hardware Compatibility List (HCL) website. This website contains a comprehensive list of computers and devices that have been tested to work with Windows Vista.
• Many devices require special drivers to work properly. Be sure that you have installed any software discs that came with the device.
• Restart the computer. Restarting might be necessary if the driver requires it or if the driver did not install correctly.
• If the device is a universal serial bus (USB) device, disconnect it and then plug it in to a different USB port. Windows should detect the device and install the drivers, and will notify you if the device drivers did not install properly.
If this does not work please come back to me
Apr 19, 2008 | Office Equipment & Supplies
Samsung SC-D353 Mini DV Digital Camcorder Logo
478 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
