Question about Kenmore 20722
Kenmore - tub does not spin
I can hear a motor running, but it is not engaging with the tub, the tub does not spin. I tried various spin settings, but had no luck.
  • 67 Answers
Motor coupler 20 bucks from the repair store 285753a is the part number i believe gl
Posted on Mar 21, 2007
Older kenmore warsher, Model num 110.14202300. not drain or spin
If it won't drain or spin check the lid switch. If it sounds like the motor is running when in spin check the coupler between the motor & and the transmission will have to pull the motor to get to it.two plastic parts with a rubber piece between them.
Jan 02, 2018 | Kenmore Washing Machines
Kenmore washing machine model 110.20901990 motor runs but will not spin. How do I fix it?
If the washer does not agitate at all, does not spin, but will still drain, this is a symptom of a broken motor coupling.
The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair that doesn't cost much. The part number is included in the link I provided. Appliancepartspros.com carries a replacement motor coupling for about $11.
NOTE: A broken motor coupling is usually accompanied by a loud rattling noise. You can hear the motor engaging and running, but there is no tub action.
If you need an illustration, you can refer to the website I mentioned and locate item 13 under the Brake/Clutch/Gearcase/Motor/Pump section.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope you find this information helpful.
Oct 10, 2009 | Washing Machines
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
I have a kenmore 70 series washer,the machine won't spin. I hear the clutch but it's not engaging. The pump to remove the water seems to be operating but the tub just won't spin and makes a loud noise.
The loud noise (sounds like rattling or grinding) is the motor coupler. It's between the motor and the transmission. This part takes the place of the belt, and costs about $20.00.
Mar 31, 2008 | Washing Machines
Spinning problem
Following your description the problem is with the lid switch. Get an access to it and find out whether something prevents his smooth movment,its has a loose wire connection or the switch is malfunction and should be replaced. Good luck!
Sep 04, 2007 | Kenmore 22422 Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
77 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
