Question about Samsung Digimax L730 Digital Camera
L730 Digimax Samsung camera owned by my daughter, we cannot open the lens on the front of the camera, normally does this automatically, but is just switching on and then just bleeping at us ......battery full.....memory card ok any ideas how to open the lens?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Feb 11, 2013
SOURCE: Samsung Digimax L730 Digital Camera
This problem is usually caused by grit in the mechanics of the lense. To resolve the problem:
1. Ensure the lense itself is clear, removing any visible objects.
2. Try tapping / knocking the camera to dislodge any obstruction.
3. Failing this you can force the mechanics by turning the lense sections - however be careful when attempting this as you may snap the lense if turned too hard or the wrong way.
Words of wisdom from: Malhotra, Manmohan
Posted on Nov 05, 2008
blueextc3221
  • 15935 Answers
SOURCE: Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Posted on Dec 27, 2008
  • 67 Answers
SOURCE: zoom lens will not open on l730 camera
hi,
its lance problem , its most probebly happens with them, you just well servise the lance , if you are a technition then try it at home otherewise contact authored person
Posted on Aug 31, 2009
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Posted on Oct 10, 2009
  • 82 Answers
SOURCE: My Samsung Digimax S800 Camera, when push power
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Posted on Jan 14, 2011
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
It takes so long to process after I take a photo,
The Samsung L730 is Intelligent LCD brightness,it automatically detects environmental illumination and adjusts LCD brightness for optimal image viewing. no problem it just working fine
Sep 28, 2009 | Samsung Digimax L730 Digital Camera
Zoom lens will not open on L730 camera
hi,
Aug 31, 2009 | Samsung Digimax L730 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
I have same prob
If the lens is uneven it may have became jamed to one side. I've seen a lot of these. The lens really should be replaced but I have be sucessful in poping them back into alignment, very dangerous however and a job best left to an expert like me. If you are going to throw it away anyway I guess you could try it at your own risk.
Jul 17, 2009 | Samsung Digimax L730 Digital Camera
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730 camera. Is fully charged. Power button is permanently on. Lens locked - can't move in or out. No display
take out the battery wait for a few sec and then put the battery back on, then switch the camera on.
for the lens try to gently force open or close the lens.
this works on my camera. i have the same problems. hope this helps.
Dec 03, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
55 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
