My CRT oscilloscope dont work. I need a circuit diagram and information to find the fault. There is no serial or model number and I have searched the web and cant find any information. the machine is Laboratory Oscilloscope Cat Q_1280 Any help would be apreciated. Thanx
  • May 11, 2010
    What's not working? Totally dead? No trace? Deflection problems?
  • Televison & ... Master
  • 2,778 Answers
Just buy a new one, they aren't all that expensive, I bought a cheap one100 meg one for 100 bucks a few yrs ago and its worked good
Posted on Mar 08, 2018
SOURCE: samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Posted on Sep 25, 2007
BFixed
  • 104 Answers
SOURCE: picture problem
Aside from the parts you mentioned check the vertical connection to the yoke (usually yellow and green wires), it may have a cracked solder joint or it could be burned. Also check the yoke for a broken vertical winding.
If the line is yellow with no other colors you may also have a bad color gun or drive transistor. If all color guns are working the line should be white.
Posted on Mar 14, 2008
  • 4234 Answers
SOURCE: sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Posted on Apr 09, 2008
SOURCE: I need a user manual for a Leader LBO 522 oscilloscope
You can find the manual for a LBO-522 (amoungs others) at http://bama.sbc.edu/leader.htm
Posted on Jul 10, 2008
SOURCE: looking for a schematic diagram of circuit board
hi'
Posted on Apr 23, 2009
What site can i use to download color tv schematic diagrams for free??
looking for one myself
so many different brands
component and circuit boards are never unified
old oscilloscope working its but off
Nov 24, 2016 | Televison & Video
Variable speed grinder model 315.17340
that comes up as a craftsman brand by sears ( mass produced )
variable speed grinder
I cant find an exploded view or user manual
if you cant get the value information
think you will be up for an oscilloscope
Jul 03, 2016 | Grinders
No display ? schematics or circuit diagram
Google search your manufacturer make, model and words circuit diagram. This information was not provided with your question.
May 20, 2015 | Televison & Video
Panasonic tv tc21gx20p diagram
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 18, 2013 | Televison & Video
Having wiring problem freezer works but fans dont come on aod defrost timer dont kick in need a wiring diagram the serial number is . 88202021 and model number is . gf2ssd for a nor lake reach in...
I have a generic wiring diagram that I use on all my installs that works very well. It is basically the same for most all commercial walk in freezers. Send me a email address and I'll scan and forward what I have.
Oct 10, 2010 | Nor-Lake Freezers
Sony tv won't turn on stand by light flashing constantly
you need the circuit diagram of the model as the fault lies in the "Switch Mode Power Supply" of the set
Aug 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
35 inch Mitsibutchi TV model #CS-35201A, serial #502637, manufactured 1993 TV made a popping sound when turned on and now only visable object is a straight horizontal colored line in middle of screen....
Hello dan82810,
The picture tube or CRT is not the problem, and yes this set is fixable. What has happened is that the vertical deflection circuit has malfunctioned. More precisely the vertical coupling capacitor has malfunctioned (The pooping sound was the capacitor exploding).
Open up your TV (take the back off and unplug the set), and look for the damaged capacitor, it will look puffy or if it has exploded.
To fix this problem you will need the schematic diagram for the TV (can be found at www.servicemanuals.net). Then you will need a multimeter to measure the DC voltages on the vertical output circuit, and finally an oscilloscope to measure the waveforms at the vertical output circuit and the input to the vertical windings of the deflection yoke transformer.
Now what you should basically find is a sawtooth wave at 60Hz which is the drive for the yoke transformer. However since the coupling capacitor is bad you will have the wave at the output of the vertical output stage, but not at the input of the yoke transformer. Use the schematic to find the value of the capacitor that has malfunctioned.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 28, 2009 | Televison & Video
CRT TV vert section
Vertical linearity is more of a DCV bias issue rather than feedback or AC coupling. Hence it would be more apt to suspect resistors rather than capacitors. Of course, it is also possible that the large IC that drives the Vertical output maybe at fault (least likely) but often would have trimpots for adjustment. Most current designs do away with trimpots and rely on self correcting (feedback loop) which is simply a resistor in the 100k range. In certain instances, it could be a thermistor or resistor or diode limiter attached to the yoke itself.
Best would be to use a service manual or at the very least a schematic diagram with voltage readings and compare actual on PCB against schematic.
If you could post back the make & model or preferably the chassis number of the TV, might be able to comment back known common vertical issues.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 05, 2008 | Televison & Video
Wiring diagrams
I am not aware of the schematics being available for free for this model, What is the problem you are trying to resolve? Perhaps the diagram is not needed.
Keep us posted.
Dan
Jun 02, 2008 | Philips Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
