Question about Ricoh Aficio 1035 Copier
How can I inter to s.p program for sharp ar-m236
Ihave error code H4 sharp ar-m236 I could not inter s.p program to reset the code
  • Ricoh Expert
  • 1,326 Answers
Basicly there is not a trick to the S.P. mode. You go in to it & touch The S.P. on the display and then turn the main power switch off and then back on and that is that is needed. But if that did not work you will need to go deeper in to the problem.
Posted on Dec 17, 2008
`How can I inter to s.p program for sharp ar-m236 H4-20
Press # - Interrupt key - C -Interrupt - Main code - Start - subcode - Start.
Mar 05, 2013 | Ricoh Aficio 1035 Copier
SHARP AR M236 H4-00
H4 Heat roller low temperature detection
Jul 26, 2011 | Sharp AR-M237 Copier
Problem with the Sharp Copiers AR-M236 Digital Image Copier I am in Cote d'Ivoire country of west Africa and the Sharp copier i use is from Italy. When the machine is put on, it keeps blinking with...
what is the supply voltage in ur area is it 220v or 110v.Most european machines are 110v and this creates problem with the fusing section.H4 code is from fusing unit .U can check the machine ratings by looking at the back or side cover where they are mentioned. is it i ok then check for broken thermistor,heater
May 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Dec 28, 2009 | Sharp AR-M237 Copier
Sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Sharp AR-M237 Digital Copier
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
Ricoh Aficio 1035 Copier Logo
298 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
