Iam using IBM computer with pentium3 when i turn on the computer this message showing OPERATING SYSTEM ERROR LOADED HOW CAN I SOLVE THIS PROBLEM
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
I have a solution for you.
I may involve changing your BIOS or complementary metal oxide semiconductor (CMOS) settings or that may require you to make physical changes to your computer hardware. Incorrect changes to the BIOS of your computer may create serious problems.
  • If you are using an IBM computer with an AWARD BIOS version 4.5x, visit the following IBM Web site: http://www.ibm.com (http://www.ibm.com)
Posted on Dec 16, 2008
'm installin win xp on my pentium3 with 10gb harddisk n 256 mb ram... it shows setupdd.sys could not be loaded error code 7 durin installation.. i tried change d xp cd 3 times.. still hav same problem
change the cd-rom unit,i know it sounds crazy but try it before you waste anymore blank discs,im a tech and that is one solution that works ,good luck
Feb 27, 2011 | Computers & Internet
Iam useing pentium3 system, fresh xp installed, sound not working , I want pentium3 xternal sound card drivers for win xp. Thanking you.
Check Your Drivers In The Control Panel Like This Control Panel, System, Device Manger, Find Sound Video And Game Controls And Check Your Audio And Sound Drivers Like This If It Has A Blue ! Mark It Is Off I Think But If Its Red Its Corrupted And You Must Reinstall The Driver Or You Could Figure It Out By Right Clicking On The Specific Device You Want To View And Click Properties And Go To The General Tab And View Device Status And If Your Device Does Have A Troubleshooter And Its Not Working USE IT
Dec 12, 2010 | Intel Pentium 3 , 450 MHz Pentium III...
I have a IBM thinkpad T40, while working on it, the laptop shut down and started to reboot. but only got to a point where it said could not find operating system.after a couple of times tring to reboot it,...
Whilst booting up have tried tapping the F8 key to get into the safe mode menu and either select the last known good configuration option or the safe mode option to load the operating system to then try and determine the cause. Should this suggestion not work a safe option to recovering your data is to buy a USB hard disc drive docking station, whip out your hdd, slot it into the docking station and retrieve your files using another PC. Repairing the operating system using the XP disc on boot up sometimes works but also trashes your personal data if it's on the C drive and it reloads the o/s.
Sep 23, 2010 | IBM ThinkPad T40 2373 Notebook
Gmail Error code # 008 OOps error while sending
Hi!
When ever iam trying to send any attachments to some id it is taking
time ,and at last iam getting a error message as
Oops.....the system was unable to perform your operation error code
008 please try again in few seceonds
pl help me how tp solve this problem this problem is comming since
morning
raju
Dec 24, 2009 | Google Gmail
My system is not going to bios set up iam getting a error message 177 system keyboard locked (my system model no is 6842-s2j ibm net vista desktop)
Okay, Do you have an ESD Bracelet? They are about Ten Dollars. You need to reset BIOS by removing the C-MOS (Complementry Metal-Oxide Semiconductor) battery and keeping it out for thirty seconds. Replace it and BIOS will be reset, and so will of the BIOS settings.If you need more detailed instructions please tell me!
*WARNING*
If you open your computer unsafely you can short the drive causing permanent data loss or system damage!!
Ryan Frame
Creative Energy Associates Technical Center
Apr 28, 2009 | Computers & Internet
Booting time its showing Error messagr internal key board error plz tell me wat is the problem....and where is the service center in bangalore.
it may be happen due to some system file is missing used for boot by system it may be solved by re installed the operating system.
by the way below the address u needed.......
IBM Service Centre in Bangalore:
IBM India Private Limited
Lavanya/Priya/Sudhir
Subramanya Arcade, Ground Floor
12, Bannerghatta Road
Bangalore - 29
Phone : (080)41953043, 3035, 3032
E-mail : tphlpbng@in.ibm.com
Mar 05, 2009 | IBM ThinkPad X41 Tablet PC
MY USB(2.0) PORT NOT WORKING
hi,
welcome to fixya.com,sir if u have already uninstalled and reinstalled the drivers and if u have already reinstalled the operating system and if it is still not working then simply replace the system motherboard.
Feb 14, 2009 | Microsoft Windows XP Professional With...
Error loading operating system
Here you go! SYMPTOMS loadTOCNode(1, 'symptoms'); When you restart your computer after the file-copy portion of Windows XP Setup, you may receive the following error message: Error loading operating system
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP. uparrow.gif RESOLUTION loadTOCNode(1, 'resolution'); Warning This article contains steps that may involve changing your BIOS or complementary metal oxide semiconductor (CMOS) settings or that may require you to make physical changes to your computer hardware. Incorrect changes to the BIOS of your computer may create serious problems. Microsoft cannot guarantee that problems that result from changes to your BIOS can be resolved. Change your BIOS settings at your own risk. If you need help with any of these steps, contact your hardware manufacturer and note that making either hardware or BIOS changes to your computer may invalidate your warranty. If you do not want to make hardware changes to your computer, you can take your computer to a repair center.
To resolve this issue, use one of the following methods: • Make sure that you are using the latest BIOS revision for your computer. Contact the computer manufacturer to inquire about how to obtain and install the latest BIOS update that is available for the computer. • If you are using an IBM computer with an AWARD BIOS version 4.5x, visit the following IBM Web site: http://www.pc.ibm.com/ww/hdd/hddredirect.html (http://www.pc.ibm.com/ww/hdd/hddredirect.html)Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
Apr 25, 2008 | Acer Aspire 5100 Notebook
Formatting problem
plz send me full configration of motherboard
Mar 04, 2008 | IBM ThinkPad T23 Notebook
My ibm t40
If there is a problem in loading the operating system it may have been caused by some change. If you can work out what stopped it from working then you can try and reverse the change. Alternatively you can try to reinstall the operating system, to do this you insert the system disk that should have come with the computer or the OS if you upgraded it and follow the instructions. You may have to fiddle around with the startup options to get it to run the disk. Most computers access these through pressing F8 somewhere in the startup sequence.
Dec 01, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
70 people viewed this question
Alun Cox
David Payne
David Payne
