This garage door appears to be "Overhead door" brand but was not sure if it is made by another company with Overhead Door's label on it? was hoping to avoid costly conversion etc! Hopefully you can suggest a remote that is compatible. Probably not even six years old...
REMOTE CONTROL 390 1 CHANNEL
Click on above link.
Good luck.
Semper Fi,
Z
SOURCE: garage door opener won't open garage door
did you use the manual release to unlatch the door from the opener? You may have a problem with the door binding and opening it manually will confirm that. You may also have misaligned the sensors at the base of the door so check that too.
SOURCE: 6 month old garage door will work.
On the back of the opener near where all those white wires go you will find 2 controls. One is labeled "up force." Increase this about 1/4 turn.
Remove the cover and take a look at the drive gear. It sounds like it is stripped.
SOURCE: lights on overhead unit on garage door opener will not go off
This is not too uncommon. What tripped the breaker in your house also got to one of the relays on the logic board of your opener. The only cure I know of is a new logic board.
SOURCE: my remote will open the overhead door when I am
Limited range of your remote controls
could be related to radio frequency interference that comes from
something in your home or in the surrounding environment. Certain
electrical devices can radiate interference; this could be almost
anything that is plugged into an electrical outlet.
Please keep in mind that the device can
be brand new, or can be an item that has been in use for quite a
while. Also, the item may continue to function properly as far as
you are able to tell. The only problem with the item may be that it
has started to broadcast the interference, with no other symptoms
noted.
Some devices are more likely to
generate interference than others. This includes TV cable, cable
amplifiers, surge protectors, fluorescent lights, battery charging
devices (power tools, golf carts, etc.), anything that utilizes a
timer (sprinkler systems, lights, alarm systems, etc.), and a myriad
of others. If the problem seems sporadic, we can safely assume that
the device responsible for the interference is only being operated
during these times. Again, please keep in mind that the age of the
device does not determine if it is capable of broadcasting unwanted
interference. Any electrical device can be the source of the problem.
The first step is replacing the battery
in your remote. If the range on your remote does not improve, remove
the wall control wires from the overhead unit. If the range does not
improve you will likely need to replace the remote control. After
replacing the remote, or if you have other remotes programmed in to
the opener, and the range problem still exists, please proceed to the
Power Down test.
Multiple garage doors:
If you have two garage door units and
one is working just fine, you will need to start by unplugging the
good unit. This will help determine if the unit with no range starts
to function properly. If the range comes back to the bad unit then
you will need to replace the logic board on the unit that was
unplugged as it is emitting an RF signal that is over powering the
other garage door opener. If the range doesn not improve after the
“good” unit has been unplugged, replace the batteries and try
programming some additional remotes to determine if the existing
remotes are the issue. If the extra remotes do not have any range
then you would need to replace the receiver logic board in the “bad”
unit.
