Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
No power up
Sylvania6842PE M (Monitor only). I moved this unit and when I plugged it into the wall at its new location something popped inside and it will not power up. The green standby light goes on. When I push the power button a relay clicks inside and the yellow power light comes on for a fraction of a second before it goes back to the green standby light. I took the back off as my local supplier only gave me a 30 day warranty and noticed that a green LED flashes on one of the power boards. It glows steady for the fraction of a second the front yellow light comes on. I checked and read 15V on this powerboard at one of the connectors marked 15V but it was only there when the yellow light was on. I cannot see anything damaged although the pop could have been the sound of a capacitor exploding.
  • 1 more comment
  • William Hyman Mar 22, 2007
    m1013
    You were correct. I found the problem an hour ago by disconnecting cables from the power board until the green light stopped flashing. All I have to do now is find Q001 which is labelled RJP3053 5661 and hope it does not blow again. I am surpised that it could blow before I had switched the power on.
  • William Hyman Dec 23, 2008
    My problem was not read very well. Q1 blew, not a capacitor. This suggestion was useless. I need to get the replacement transistor or the sub assembly.
    It sounds good and I will order and install the part.
    Many thanks.
    I will bug you again if it does not fix it.
    Sergeant:
  • 367 Answers
I just wanted to make sure this issue was resolved. I see no activity on it since the end of December. Let me know
Posted on Jan 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, to my understanding, it is required that plasma TV units when unplugged/power removed should allow sufficient time to dissipate whatever stored electrical energy is present inside, otherwise power supply failure is imminent.
To your concern, you may want to check out this site for possible board replacement.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 23, 2008
  • Sylvania Master
  • 19,396 Answers
You need a reay, RJP3053
Buy from RELAY STD DPDT for $ 2.79
    President:
  • 2,110 Answers
Http://i133.photobucket.com/albums/q68/rwlib3/DSC_0426.jpg
IT might be blown capcitor
If a capacitor blows out, then it is probably having a higher voltage
on it than it is rated for. You don't say what the voltage rating was
for the original capacitor or what the voltage rating was for the
replacement. Did you try to measure the voltage in the 10 seconds
before the replacement blew??
Kettle motor wont come on and light wont come on
Check that the wall outlet is good by plugging something else into it. Plug the pop corn device into the outlet. Bend the power cord at both ends to see if the unit lights up. If not, you may have a bad connection inside or a bad switch. There also may be a blown fuse inside you could replace.
Dec 13, 2014 | Gold Medal 2086 Popcorn Maker
No power
Look if you can safely get it apart for the fuse inside the unit and if possible test the power cord and where it connects, this is the place to begin---total dead units are usually easy to fix, follow the AC voltage from the wall or voltage source inside to the fuse etc.
Dec 20, 2012 | Acer S242HL bid LCD Monitor
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
MA203DT monitor dead again
I think it's trying to tell you something!
Time for a funeral. Best get a new monitor.
Oct 03, 2009 | iiyama MA203DT 22" CRT Monitor
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
Lcd srceen
first check the wall socket, plug in a lamp or something
the transformer/power-supply unit may have failed(no little light) but since this is first connection to a different point there may be a popped breaker or fuse on the wall socket
Jul 05, 2008 | Acer Aspire™ T180 PC Desktop
No Power
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
May 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
541 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
