Question about Nikon D50 Digital Camera with 18-55mm Lens
Won't Take Picture Sometimes
For no apparent reason, my camera will not take a picture sometimes. The camera window displays a flashing error message "F--", which I cannot find in the manual. It then flashes some info like "R9". Perhaps a few minutes later, the camera will start taking pictures again. This is very annoying. Help?
  • doodybug Nov 01, 2007
    My camera will not take a picture. It is flashing (r27). I do not have a manual. Does anyone know what the problem is?
  • skmc0326 Oct 01, 2008
    I will be taking pics and then my D50 won't take a pic and, with the shutter button fully depressed, it reads "r27". It usually happens when I'm not at the widest angle of my zoom lens. If I back it off to the widest angle, it usually will take a pic, but I want to be able to zoom. I can't find the "r27" code (displayed in the lower right corner of the view finder) in the Manual ANYWHERE! Weddings of Your Dreams turn into Weddings of My Nightmares!
I have the same problem with my D50. I believe it is caused by poor electrical contact between camera and lens. The contacts may be dirty but I have tried cleaning them and I still get the same error. Moving the lens often solves the problem. This led me to suspect that it is due to slight wear of the plastic mounting bayonet on the lens. This allows the lens to fall slightly and disengage from the contact pins. My 70-300mm lens has no problems since it only uses a few pins.
Posted on Apr 23, 2007
SOURCE:
My motorola triumph won't send pictures mms
Check your APN settings
http://www.virginmobile.co.za/support/support-category/general-services/gprs-settings-and-usage/gprs-and-mms-settings-for-android-phones/
different locations you go sometimes have dead spots so less signal wont send mms. you can also connect to your home/public wifi to send mms,
May 03, 2017 | Motorola Mobility Triumph
I gotmy new finepix camera in December. it works fine but sometimes when I am looking back at pictures I have taken it say read error and cant see the picture. what is the reason for this and can I fix it?
There can be two reasons for this problem.
  1. Might be your memory card is not working properly. Thats why reading or writing errors occurs most of the time. Try again by changing the memory card.
  2. Sometimes the data writing process of the camera could e malfunctioned, if so you have to give this to professional camera repair center.
Feb 28, 2011 | Cameras
When i press to shoot a picture, the focus is moving back and forth. sometimes it will take a picture, sometimes it does not come into focus and will not take the picture. I have charged the battery...
Hi, check af mode settings in upper display ;set afs,central af area clean contacts of lens cpu and in body too. Set the manual focus mode and check in viewfinder if the focus indicator LED light no flashing.Can make focus your camera dont have problem ,the lens may need maintenance (clean) or repair.
Greethings!
Feb 19, 2011 | Nikon D80 Digital Camera
I have a DSC T70. Sometimes i get a message "File Error" for some of the pictures. For these pictures, the file does not show and when printed, the picture is merged with another picture.
The LCD screen of the Camera may display a FILE ERROR message when trying to view a still image on the Camera if the image was rotated, modified and overwritten using editing software on a Computer.
To play images you have taken on the Camera, it is recommended that you do not make any changes to the original image files.
Aug 28, 2009 | Sharp Cameras
Canon Rebel XSi seizing up?
u have lens problem is u see any error in display error 99
Jun 22, 2009 | Canon EOS Rebel XSi Digital Camera
Error message for olympus camedia digital camera D-560 Zoom
When I transferred those particular pictures to my laptop for some reason they were partially deleted from the camera which gave the 'picture error' message. Deleting that picture completely got rid of the message.
Nov 19, 2008 | Olympus Camedia D-380 Digital Camera
Flash on Cyber-shot DSC-W50 not working properly
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Dec 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
340 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
