Question about Sierra Voltage Regulators Voltage Regulator 5723 UPS System
Starting probs Having fully charged the battery and put it on the car, the battery light goes out when the car has started but when I stop the engine the lit comes on again, does this indicate that the alternator is at fault?
    Brigadier General:
  • 5,158 Answers
Ok.... quick test that you can do at your own risk as i'm told it is dangerous.... wear safety googles at the very least... start the car... unhook the battery.... if the car dies... it's the alternator... if it keeps running... it's the battery.... loosen the bolt on the battery post before you start it so it's easy to take off.... after you have removed the connector and determined which is at fault... don't hook up the cable again untill after you shut off the car.... what you need to guard against is creating a spark....
Robert
Posted on Dec 16, 2008
Why is fully-charged battery too low to start within 6 hours?
It is not impossible for new batteries to be at fault , check with high discharge tester, if OK there is a short circuit or something using up power such as stop lights on. to check remove the + terminal on the battery insert a amp meter current draw should be almost zero , small current draw will be from clock ECT.
Dec 11, 2015 | 1998 Dodge Stratus
Mitsubishi Pajero ModelGH -V75W Engine#6G74 car not even starting how will I put off the parking hand break light ,ABS light and also some auto gear transmission light on same time when ignition puts on...
first make ur car battery fully charged,
then make sure to connect battery terminals finally and use a best plugs for ur pajero and then u will see hope fully car will start
Oct 10, 2014 | Cars & Trucks
Left lights on my jeep cherokee have recharged battery but it goes flat with in minutes and engine dies
Run this by me one more time your Post doesn't make sence. Is Battery light on? Is alternator working properly 13 to 14 Volts You Must have a fully charged Battery to test. Get tested at your Local Auto Parts Store after charging
Jun 09, 2014 | 1994 Jeep Grand Cherokee
Ford explorer 2004 reset anti theft
Is this a new key? If so that is the prob if all else fails call lock smith
Jan 21, 2014 | Cars & Trucks
Will not start
Clean and lightly oil the brushes in the starter motor,common prob. they get sticky.
Jan 16, 2014 | Polaris 2004 Sportsman 500 H.O
Having electrical problems with my 88 suzuki smaurai. New battery and new alternater. seems to drain almost immediatly ifi turn o any auxillary items such as head lights or whippers.
had the same thing happen to mine, apparently the ground wire was so corroded inside the insulation that the alternator could not charge the battery, soo replaced both cables and have never had that prob. since.
Nov 13, 2011 | 1988 Suzuki Samurai
Ok here is a weird one, my truck has power, I put the key in, and I have no chip in my key by the way, I turn the truck on it goes through the motions, when I hit the start position all it does is goes...
I have seen this before. And I would almost bet your Battery Voltage at the starter will be 6 Volts or below 9 Volts. It is a combination of several things. There are some TSB solutions for electric problems but you need to get a code from a scanner. Autozone, Oreillys and Advance will scan for free. But your particular problem may not set a "check Light"
If your Battery is not fully charged, which would be 13.2-13.6 Volts, you can have problems from the Antitheft system. When activated the Antitheft system drops the Voltage to a level the starter will not work with, to prevent theft. Have your Battery draw tested and if replaced, only put in a fully charged battery.
Another thing that can happen is intermittent charging. Even with a jumper vehicle, your truck will start and within 3 minutes of having the boost removed your own truck will fail to charge. People have stalled their trucks at 70MPH or after driving for hours they have a dead battery. The dash Voltmeter will indicate a discharge but most people do not look at the gauges.
I suspect if there is a Battery Saver system in the truck, it is that system which may be breaking the power connection to save power from the drain. Unfortunately the drain is the engine running or the starter trying to work. So I suspect the Battery Saver can be a part of the starting problem too!
I hope my solution is very helpful to you. You need further testing to sort this out. I would like to know what you find out to fix this problem.
Mar 31, 2011 | 2004 Ford F150
I drove my 2001 Windstar to work with no problem, went out to go to lunch and the engine would not start. Put battery charger on it, but it says it is fully charged.
check and clean the battery posts first. Do the headlights work ok, and dim when you turn key to start?
Any clicking?
Try staarting in neutral. turn key to on, apply brake, shift to neutral, try to start.
report results
Jan 07, 2011 | 2001 Ford Windstar
I was wondering if there was a way to get the codes from the computer off of my 1999 jeep grand cherokee. one day it just stopped working and i'm pretty sure it's the alternator but not sure. help!!
sure!can you charge battery? if won't start charge the battery and take it to nearest autozone or advance auto parts and as long as your check engine light is on,,, they will code read for free, then they will tell you what or where problem is.if not then try this,,,put in fully charged battery,start it,,disconnect the positive cable from battery while engines running,careful not to let the positive cable come in contact with any metal of car, if engine dies,,altenator not charging,may be bad diode in back of the altenator or blown fuseable link inbetween starter and altenator.hope this helps and if so please note so in response. thank you for choosing fixya.com
Jan 06, 2011 | 1999 Jeep Grand Cherokee
Replaced ignition switch 2003 chevy impala and car will not start
After you replace the ignition switch turn the key to start the car and release leave the key were it stops after trying to start wait 10 minutes until security light goes out turn key to full off position then repeat the above procedure two more times for a total of three on the 3rd attempt to start car wait for light to go out then turn key to full off positoion wait 10 seconds then try to start car body control module should learn new pass code and the car should start.
Big john, J@J Automotive
Sep 15, 2009 | 1999 Chevrolet Lumina
Sierra Voltage Regulators Voltage Regulator 5723  UPS System Logo
Top Sierra Computers & Internet Experts
Glenn
Glenn
Les Morrison
Les Morrison
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
