Question about ACI Pacific Image Prime Film PF3650 Pro Film Scanner
Line down side of image
4mm in from right on every thing I scan
Unable to fix as scanning head had it needs new head repair costs more that new scanner yet another for the scrap .Isn't wonderful .
Posted on Dec 17, 2008
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Smartimage problem on screen
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Apr 14, 2010 | Philips 220CW8FB 22" LCD Monitor
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Aug 07, 2009 | HP Office Equipment & Supplies
Black line down the right hand side of everything I scan
it is problem your copier scaner mirror is derty
clean it
Jul 22, 2009 | Brother MFC-9440CN Laser Printer
My scanner always scans with blurry lines across scanned images from it
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
Feb 09, 2008 | HP Photosmart C3135 All-In-One InkJet...
Brother dcp 7020 Scanning to e-mail
with Brother -photo capture-copy-fax-scan machine, I can do except scanning. Please show me how to enable scanning
Feb 01, 2008 | Brother DCP 7010 Multifunction Laser...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Bushnell 18-1560 Telescope
What you have is called a refractor-type telescope with the primary lenses (the Objective) at the top of the tube and the only other lenses in the system are your selection of eyepieces, probably a barlow lens (2X magnification of any eyepiece used), and a diagonal (in line mirror so that you cand see into the telescope from the side.). As the focal lenth of the eyepiece decreases, so does the distance away from the Objective Lens. I believe that you are using the telescope with a diagonal mirror which makes the optical path longer. The fact that your longer focal lenght eyepiece can focus and not your short one would be only if you didn't have the diagonal or the eyepiece all the way in tight to allow the focus mechanism (rack and pinioin) to get compressed enough to focus. Look at the Moon, if the image gets smaller then bigger as you focus, but not sharp, then I would have to tell you that your eyepeice lenses are not in the right order. Someoner may have taken it apart and didn.t put them back in the correct order. The lenese could just be very dirty also. Barrow a short focal lenght eyepice from a friend and see if it works in your system. Then you will know for sure.
May 15, 2007 | Bushnell Deep Space 18-1560 (150 x 53mm)...
ACI Pacific Image Prime Film PF3650 Pro Film Scanner Logo
115 people viewed this question
Top ACI Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an ACI Office Equipment and Supply Expert? Answer questions, earn points and help others
