Question about Motorola Mobility H350 Wireless Headset
H350 wireless will no work with my playstation 3 system
I need the passkey in order to make a connection with my ps3. The system see the device, but I cant find the passkeey that it needs to use the device. what can I do?
  • keegster1010 Dec 20, 2008
    I also have the same problem and used the passkey 0000, but i cannot hear nor speak throught the headset. When i play a game it shows my headset but i cannot hear anything through the headset. Any suggestions
  • Anonymous Jan 08, 2009
    i see the headset but i cant hear or talk into it.. I need help with this
I just did this exactly with a motorola h350. . .the passkey is 0000 after u enter it its gonna register and say complete =)
Posted on Dec 18, 2008
What does error code 80010009 for the crysis bluetooth 2 mean
Incorrect passkey for Bluetooth device. Description: Entered wrong passkey for the Bluetooth device when trying to pair it with the Playstation 3.
Source: http://us.playstation.com/support/answer/index.htm?a_id=939
Aug 13, 2011 | Sony Playstation 3 (PS3) Console
Need passkey to connect motorola h350 to my new phone
The default Motorola passkey is 0000, try hat now, but be sure to follow the instruction to which you will link you bluetooth headset!!
have fun
Jun 27, 2010 | Motorola Mobility H350 Wireless Headset
Can i use my h350 bluethoot with a playstation 3 ?
Yes,
It should work with your ps3. Here is a link with all the steps for connecting a bluetooth headset to a ps3.
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
Thank you,
Lee
Dec 16, 2009 | Motorola Mobility H350 Wireless Headset
Trying to connect my blutooth tp my phone dont know passkey code number. Can you help Motorola H350 is the model number of bluetooth
passkey is of ur choice..
only remember that it must b same on both..
it can consist of a single digit to 4/6/8 digit(s)..
eg: if i u type '0' as ur passkey at ur bluetooth tp..u gotta give '0' to ur ph also..
very easy..
try to seek professional advice of ur system admin/vendor....
Nov 16, 2009 | Motorola Mobility H350 Wireless Headset
I need the passkey for my H350 Motorola Bluetooth. I am trying to set it up with a new Samsung phone. Can you please provide the passkey
Hello there
The universal pass key that all of these leave the factory with is 0000 (four zeros).
Hope this helps, please don't forget to rate me.
Thanks
May 20, 2009 | Motorola Mobility H350 Wireless Headset
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
I need my pass key so i can use it H350
the default passcode is 0000. I hope that helps.
Sep 23, 2008 | Motorola Mobility H350 Wireless Headset
Connecting Motorola H350 to PS3
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Feb 26, 2008 | Motorola Mobility H350 Wireless Headset
Motorola H350 doesn't connect...
The issue is with the PS3s compatibility with the H350. Sony should be fixing some of the issues with an update, but from what i've checked online, the H350 is a problematic headset. i just got one as well, and have connection issues with it online.
Nov 24, 2007 | Sony Playstation 3 (PS3) Console
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility H350 Wireless Headset Logo
182 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
