Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
TV has sound but no picture
When turning the TV on, there is a slight cracking/static sound that occurs. The RED light somes on, then in about 5 secs, the green light adjacent to hit, will flash for 3 secs (simultaneous to the red being continuously on) and then both will shut off with the sound of the TV. This will be automatic without prompt of the remote. After that, the monitor will automatically turn itself "on" (with no picture) with only the sound being displayed.
This will continuw 3,4 maybe 5 times than both green light and red light will both flash with NO sound nor picture.
What is the problem with the monitor? What do I/should I do???
I have a Toshiba Model 52HM84 52" TV
  • 2 more comments
  • Anonymous Feb 14, 2009
    I also have the cracking sound and no picture. I have purchase 2 new bulbs and neither brought back the picture. I have sound, the usual flashing lights indicating a bad bulb. Where do you find the fuse and how do you know if the fuse is bad.
  • Anonymous Mar 08, 2009
    Flashing green and red light indicate bulb is finished.
    Replaced it and everything was ok
  • sherri15 Mar 13, 2009
    i have the same problem. My Toshiba 52hm84 model has sound but no picture. What bulb do u get to replace it?
  • Dr_Mark May 15, 2009
    We were watching a movie on our Toshiba 52HM84 (about 4 years old) when I heard a quiet pop and the screen went dark. Now it cycles the power 4 or 5 times with the red and green lights going thru their green on, red on, red blink, then both off sequence. The sound comes on the first few times then it stops trying and shuts off.
    Problem Solver:
  • 19 Answers
It is possible one of the internal fuses blew out.
It could be a bad horizontal outut transistor.
It could be a bad secondary of the power supply went bad
And many other things.
If it's just a fuse, it won't cost much, but a lot of them do not look like you would expect a fuse to look like.It might be a little yellow, green, or gray rectangualar box shaped part. :D
Posted on Dec 16, 2008
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Popping sounds only during video/ you tube on tv from my computer.
Because of the amount of voltage required to run the older-style "tube" televisions, many problems, sounds and noises occur in tube televisions than in the newer, flat-panel televisions. Sounds occur for multiple reasons, with some being just part of the normal process these televisions run through in order to operate. On the other hand, some of these noises may indicate a problem with the television that could warrant repair.
Worn Insulation
Voltage against metal. Inside your television's tube, there are many wire parts that electricity runs through in order to make the television run. Usually, these parts are insulated with a rubber or foam casing that prevent the sound of the electricity. If the insulation surrounding these components is thin, weak, worn or absent, you are bound to hear buzzing, popping and cracking sounds coming from your television. While this may not mean you have to run out tomorrow and get a new one, the chances are that your TV's tube is working extra hard to make it all happen for you, and you may want to start pricing new sets for the near future. b> Static During Warm-Up b> Just like rubbing your feet on a thinly-carpeted floor can cause static electricity, the same can also build up inside your television. If the noise is relatively subtle, only occurring when you first turn it on, and not overly-disturbing, the chances are that the cracking and popping sounds you are hearing are just the television's way of warming up and getting rid of the unnecessary electricity. Bad Lamp b> Deep inside the heart of your tube television, there is a light-bulb fixture that makes the entire unit light up so that you can see a picture. If the cracking and popping sounds you are hearing tend to go along with the picture on the TV becoming unclear, it could be that the picture tube is failing. It is very difficult and costly to replace the picture tube on a tube TV, so this is an instance where you may benefit more from buying a new television than taking the old one in for repair. Hope this helps.
Dec 21, 2012 | Computers & Internet
Hi I have 32LG3000 there was some static discharged from me to HDMI cable to the tv and now the picture is shutting down after 5 sec so basically I get picture and sound the top half of the picture is...
The spark has damaged the image processor - the entire mainboard (the board that carries the processor and the AV connectors, including the HDMI) will have to be replaced. The board will cost you around £50 - you can buy it from here
http://www.sparedparts.com/products/details/32lg3000_main_board_lg_ebu43398305/
or you can order it at a dealer
Dec 19, 2010 | LG Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Tv - jvc av28ct1eks model
Re JVC AV28CT1EKS reverting to standby, Try changing C521. pt number QFZ0200-302 Good luck! Nick
Jun 08, 2008 | JVC Televison & Video
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
437 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
