Toshiba satellite note book
Letters and Numbers are mixed up : Eg if one presses L , the number 3 appears. 0 = * and so forth
    Scholar:
  • 46 Answers
Your laptop keyboard has a modern emulated numpad. It acts like the numpad on a regular keyboard (since there clearly isn't room for one on your lappy).
Make sure that you are not holding the Fn key while typing, and most important, turn off Numlock. (There should be a button for it on your keyboard and a light that shows if it's on accordingly, the light should have a number and lock logo on it).
Hope this helps! Stay spicy and happy lappying!
Posted on Dec 16, 2008
Toshiba Satellite L855D keyboard does not work
Hi ,
there is a fuct key or fn key , look in your owners book to see what fn key yoou hit , too make it normal ...........good luck Roy
Dec 19, 2012 | Toshiba Satellite L855D-S5242 15.6-Inch...
Toshiba satellite c655d-5332 keys problem
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Sep 23, 2012 | Toshiba NB205-N210 Netbook
Keyboard letters are numbers and numbers are letters
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
Some of my keys are printing differently in my Toshiba Satellite A75 S209 Laptop
You need to turn off the Number Lock. Press the ScrLk/NumLk key it is located near the F11 key. When you turn off the number lock the NumLk LED light will also switch off and you will get letters instead of numbers.
Feb 20, 2012 | Toshiba Satellite A75-S209 Notebook
Numbers instead of letters
I think you may have the numlock key on.
press and hold the 'fn' key and press the 'Numlk' key (F11)
this should turn off numlock and fix your issue.
Nov 08, 2011 | Acer Aspire One D255-2670
Very simple question - which number is the serial number? Nothing appears to be indicated clearly to be it. There is a WIP ID number appearing to either start with IN or N followed by 13 numbers and 1...
LG products usually have a 12 character serial number format, comprising mixed letters and numbers, e.g: 123ABCD45678.
If you can find a number on the manufacturers sticker consisting of, 3 numbers, then 4 letters, then another 5 numbers (as above), this will be the serial number.
Hope this helps.
Regards,
BElectric
Jan 07, 2011 | Televison & Video
When typing certain letters or numbers other letters and/or numbers automatically appear. Example when i type the "p" a space automatically appears; (p ap er). When i type the number...
Well it could be several things, not the least of things is radiated electrical noise. Seriously, I had several customers get hit with this problem. One test was to hold your hands just over the keyboard. If random characters appear, you sitting within the radius of a strong transformer.
Look around the area you are in, do you see any type of antenna nearby? If you do, rotate your lap top 90 degrees.
Also, the keyboard may be starting to fail. From your description I would suspect that the scan code for the key you pressed is not getting reported back to the CPU properly.
Replacing the keyboard on a Satellite is fairly straight forward. The replacement part from Toshiba only cost $35. and that included shipping.
Don
Nov 17, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Need instructions for keyboard toshiba satellite laptop , need to know what keys to push when using the numbers in the keyboard that are also letters
No need for the instruction manual. When your going to use the numbers that are inside of the letters, hold down the the FN key and then push the number that you want to be displayed. For example holding down the FN key and then pressing the L key produces the number 3 for me. Try your keys out and see what you get.
Jun 02, 2010 | Toshiba Satellite L45-S7409 Notebook PC
Numper pad usase on compaq persario Note book PC
You need to get into your SETUP routine and enable NUMPAD function
Mar 04, 2009 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
195 people viewed this question
Alun Cox
David Payne
David Payne
