Question about Kenmore 22422 Top Load Washer
Washer leaking I am having a problem with my washer. the problem is that everytime i wash a load of clothes the washer leaks from underneath. Could you tell me what could be causing this. It isnt alot of water but enough that if it would sit long enough our floor will start coming up.
    President:
  • 878 Answers
Bestsy, your pump could be weeping. Sometimes they will develope a small leak and sometimes they let loose. They are easy to change, 2 clips and 2 clamps. Check out the photo, other things to check would be the hoses at the fill valve and the drain hose. Sometimes overloading will cause an oversplash. Catriver..post back.
Posted on Mar 21, 2007
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Sean
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
Water underneath my Sears Kenmore washer. Ive had
It could be splashover depending on what you have in the washer (different load sizes). Sometimes the water just splashes over the sides. But I have seen pumps that leak out their seal intermittently. I would suspect the pump.
Dec 30, 2009 | Kenmore Washing Machines
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
I have a kenmore washer that is leaking bad underneath in the front making puddles of water. Im constantly keeping towels down everytime I wash a load. Could you please tell me what might be wrong? Thank...
Check the front door boot first. Make sure that there are no tears in it.
Remove the back of the washer, start a fill cycle and observe outer tub sections and hoses for leaks. This is a good place to start.
Jan 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking, not found in owners manual
If it leaks during drain or spin cycle, it means that your exit hose has come loose or has a break. This can be replaced easily.............
Jan 02, 2008 | Maytag SAV515DE Top Load Washer
Kenmore 22422 Top Load Washer Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
