Question about Canon imageRUNNER 5000 Copier
Eoo7 you need to replace fixing film there is no way to make remedy?because the edge of the film is not in proper position YES I REPLACE THE NEW FIXING FILM STILL I AM GETTING THE SAME ERROR E007 AND THE FIXING ASSEMBLY CANNOT GET HOT(ANY PROBLEM WITH THE THERMITENCE?) OR I MUST CLEAR THE ERROR TROUGH THE SERVICE MODE? YOUR ADVICE WILL HIGHLY APPRECIATE SINCE IAM CONFUSE. P.S:whhat i see to access the service mode of a Ir 2016 is so differnt to IR 2200canon.please any help to known how to access the sav mode of ir 2016.thanks in advance
  • lukanzu Dec 16, 2008
    how to do a hard reset?
    Guru:
  • 1,894 Answers
Did you try a hard reset? if not please try that and get abck to us
Posted on Dec 16, 2008
Canon iR2018N showing system error E007
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
pic of fixing film
Feb 22, 2015 | Canon iR2018N
CAnon xerox Machine IR 2318 L Error code : E 000007-0000 solve my problem
E007-0000 Description Fixing film sensor failure
The fixing film sensor is faulty. Remedy - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Jan 31, 2015 | Canon Office Equipment & Supplies
My machine iR2016 is showing system error e007. wahat should
DEAR
THE PROBLEM IS DUE TO WORN OUT OF FIXING FILM ASSY.
YOU CAN REPAIR IT BY CHANGING THE SLEEVE OR REPLACE IT.
THANKS.
Dec 30, 2014 | Canon Office Equipment & Supplies
What is remedy error code E000007-0000 for canon imageRUNNER 2422/2420
A E000007-0000 means that the fixing film is out of "HP" The fixing film has a white patch that is the home position and as the film is turned, there is a sensor that reads it in & out of "HP". Odds are that the film is ripped on one side and the film moved toward the front of the copier and the sensor can not read the patch. You will need to replace the upper film unit or the whole fuser unit to repair the problem.... Good Luck
Sep 18, 2012 | Office Equipment & Supplies
How can i solve this errorcord eoo7 canon IR2016J
1. Check fixing film sensor.
2. Check fixing film sensor connector.
3. Check fixing film.
Apr 16, 2010 | Canon PC-940 Black and White Copier
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
E007ON IR2016(FUSER FILM OFF TRACK AND WILL NOT REPAIR ITSELF)
oh.....
the fuser film sleeve of IR 2016 and IR2200 are the same size.
please check the other reasons...
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Eoo7 on ir2016 how to solve the problem
hi
Dec 13, 2008 | Canon imageRUNNER 5000 Copier
Canon c122 copier code EO 07
EOO7 error means: fusing film damaged or out of position. This means that an error has occurred with the fixing unit. This is the hot bit the paper goes through just before it comes out of the machine. It consists of a lower roller and above that a thin loop film of thermal plastic with a ceramic heater inside it. It is almost certain that this film has become displaced or damaged. E007 means that this film is not rotating correctly or jogging back and forth over the sensor. It will need a new fixing film. Did you run the adjustment for installing a new fuser film when you installed the fuser? Other than that, just check to make sure the film isn't broken or missing a piece.
May 03, 2008 | Office Equipment & Supplies
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
123 people viewed this question
old marine
old marine
