Question about HP Photosmart 3210 Printer
Ink system failure on printer hp photo smart 3213
I had this message (ink system failure ar this code 0xco5d0281)
note: i change the cartridges with new one and iam olso i had the same code Yes I do have the same problem, I have gone to Hp workshop but no solution were given, they kept the printer over there and bring it back to me saying "its working now". But when I had tried it, I faced the same problem again.
Can someone help us please !
  • stonehas_lif Feb 02, 2009
    my printer 3108photosmart (ink system failure error 0xc180507
    i have hp3108 printer had problem (ink system failure error 0xc180507
  • 4,041 Answers
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
2 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: ink system failure on printer hp photo smart 3213
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
Hp 8600 missing or damaged print cartridge how to fix?
If you observe the error message "One of more ink cartridges may be missing or damaged", "Cartridge Damaged", or "Ink Cartridge Failure", "The following cartridges are not intended for use in this Printer", etc. then the printer is not recognizing the installation of the refilled ink cartridge(s) or 'smart chip' which is affixed to the rear side of ink cartridge is causing the detection issue. This type of issue can also be caused by a bent pin on the PRINTHEAD assembly or one (or more) electrical contacts are dirty on the PRINTHEAD assembly (especially if the same error occurs with a brand new HP ink cartridge). Typically, the problem is usually an incompatible smart chip which is affixed to the rear-side of the ink cartridge.
(1) It is first suggested you remove the respective ink cartridge from the printer and thoroughly clean the cartridge's smart chip's gold contacts/electrical surfaces using an isopropyl dampened lint-free towel. Ensure no ink residue is present on surface of the chip. Also ensure the chip is located in the proper position. Please refer to the 2nd photo on the following Inkjet411 support page - carefully inspect chip position to ensure it was properly placed: http://inkjet411.com/?page_id=1999 Following cartridge 'smart chip' gold contact cleaning, please re-install the ink cartridge and retest.
(2) Remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Please refer to printhead removal procedure below for reference. Often, you can gently bend the pin back into position to correct the issue.
REFERENCE: HP Officejet PRO 8600 Printhead Removal & Replacement Procedure:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02871867
SPECIAL NOTE FOR BRAND NEW HP PRINTER MODELS (temporary issue until approx. mid to late August 2014):
If you continue to observe "One of more ink cartridges may be missing or damaged" alert messages, please note that printer firmware versions CKP5CN1334ER for the newer HP Office jet Pro 8100 and 8600 printer series (manufactured after Nov./Dec. 2013) do not allow the replacement chip to function (this problem temporarily impacts brand new HP printers only -- this problem will be resolved sometime in June 2014 with the release of upgraded smart chips to all Costco stores which will work in the newer printer models).
Confirm if your printer is impacted:
1. Verify 8100/8600 printer firmware - print the PRINTER STATUS REPORT or PRINT QUALITY DIAGNOSTIC page to verify your firmware version.
2. To print the printer status report, on the printer control panel, press and hold the (Cancel) button for three seconds (i.e. 8100 models). Alternatively, you can print either of the reports from the TOOLS menu if this does work.....OR.......
3. Check 'Product Information' - 'Firmware Version'
a. CKP5CN1334ER for the HP Office jet Pro 8100 and 8600 printer series
b. If your printer has this printer firmware version, then you may be impacted.
If the error message persists then we suggest you return the cartridge(s) to your refiller and request to have the 'smart chip' (attached to cartridge) replaced with a new chip*. If Costco does not have the NEW CHIP VERSIONS yet, then request a refund for the refill purchase.
However, if the same problem occurs with a 2nd cartridge (or manufacturer's brand new ink cartridge) then the PRINTHEAD may either have ink on the internal electrical surfaces (where cartridge mates to it) or the PRINTHEAD may have a bent or deformed contact pin. Remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Refer to printhead removal procedure below for reference. Often, you can bend the pin back into position to correct the issue.
You should also ensure the EXTERNAL electrical contacts on PRINTHEAD are clean of any ink residue. Clean with damp towel to remove residue. Refer to the 5th photo on the following Inkjet411 support page: http://inkjet411.com/?page_id=1999
ADDITIONAL ERROR MESSAGES / NOTES:
2. An "Ink Cartridge Depleted" message can be observed (printer will cease print operations) when an ink cartridge 'really is' out of ink. HP has small sensors which look into the bottom of the ink tank to ensure ink is present. Typically you will receive 'Low Ink Warning' messages just before this occurs.
3. Since the printer monitors ink usage/drop counts, it will display the 'Ink Sensor Warning' messages when it 'predicts' the cartridge should be out of ink, but these messages can be temporarily ignored and you may continue printing. Eventually the 'Cartridge(s) Depleted' alert message will be displayed when the cartridge truly is out of ink.
4. The "Use Color Ink Only" or "Use Black Ink Only" messages can be caused by poor contact (i.e. electrical connectivity) between the ink cartridge's 'smart chip' and the carriage assembly (which the ink cartridge plugs into). Typically a 'Red X' will also be displayed on printer control panel LCD or Window's pop-up screen when this condition is present.
*This type of error may be caused an electrically damaged 'smart chip' which is affixed to the rear side of the cartridge itself, a mis-aligned chip (wrong position), an incorrect replacement chip type (i.e. operator installed the wrong chip on for that color and/or tank size). In most case the cartridge will need to have a new replacement chip installed by the refill operator. We apologize for the inconvenience if either of these possibilities prove to be the root cause. For more information on chip placement, refer to Section A on the following Inkjet411 support page: http://inkjet411.com/?page_id=913
COMPATIBILITY NOTE: Compatible (clone) HP 950/951 ink cartridges, sold via the internet or similar, may not be refilled and reprogrammed successfully - Costco does not (should not) support refilling of compatible ink cartridges (i.e. those cartridges which do not have the HP original blue/black logo displayed on the front label of the ink cartridge). If you had a compatible/clone/remanufactured ink cartridge refilled we cannot guarantee it's performance.
Please let us know if this does not remedy the current error condition. For any additional questions please contact us directly: Inkjet411help@gmail.com
If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
-Thank you
Inkjet411 Team Member
Aug 01, 2014 | HP Officejet Pro 8600
How to fix hp 8600 damaged cartridge message?
*This type of error may be caused an electrically damaged 'smart chip' which is affixed to the rear side of the cartridge itself, a mis-aligned chip (wrong position), an incorrect replacement chip type (i.e. operator installed the wrong chip on for that color and/or tank size). In most case the cartridge will need to have a new replacement chip installed. For more information on chip placement, refer to Section A on the following Inkjet411 support page: http://inkjet411.com/?page_id=913
If you need to purchase a new HP 950/951 ink cartridge, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
-Thank you
Jul 31, 2014 | HP Officejet Pro 8600
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
Hp photo smart 3213 error code: Oxc18a0401
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Apr 28, 2010 | HP Photosmart C7180 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
Ink system failure message in an hp photo smart all in one 3213.
Solution To resolve the issue, use the following steps. Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
If the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
Mar 03, 2009 | HP Photosmart 3210 All-In-One InkJet...
Solution
Wait two minutes.
Nov 09, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart 3210 Printer Logo
334 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
