Question about JVC XV-S500 DVD Player
HELLO When I press the power button it flashes "HELLO" on the display once briefly then turns off. It will not open when the open button is pressed. I have tried to unplug it and let sit overnight then plug in again and it did the same thing. I tried to reset it by holding the stop and play buttons in while plugging it in to get into the test mode then hit the pause button which is supposed to reset it and it did go into the test mode but it did not fix the problem.
I also the same JVC XVS-500 DVD that flashes "hello" and then turns off. I took it apart and cleaned it and tried the test and reset; no change.
Posted on Jun 15, 2008
  • 68 Answers
First thing, you need to check why it is not opening. do you hear sounds when you push the open button. if you do, there is a broken rubber band. open the cover of the device, take the dvd playing section, (make sure when you unplug wire to know exactly where they go) once you change the rubber band, try to play and see if not, reset the machine. good luck
Posted on Apr 09, 2007
I had the exact same problem yesterday (4/8) and just playing with the open/close button several times the drawer finally opened completely and closed like it should. i then did the reset sequence and all is back to normal
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Print error 5200 on 340 canon
Hello!!! How are you.
You need to reset the printer. Try the steps:
• Plug in the power cord of printer.
Press Resume button 2 seconds
then press the power button until the green light on (when pressing the power button,Resume button)
• Then release the resume button, but do not release the power button.
• While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
• Release both buttons simultaneously.
• Led will blink briefly and then will glow green.
• And the computer will detect new hardware, just ignore ...
• Press the power button again then the printer will flash and. Printer is ready for use.
www.smoothprinterservice.com
Dec 16, 2012 | Canon PIXMA MX340 Wireless Office...
How do i set the clock on jvc rv b90?
Hello
To adjust time:
1 Set the power button to ON
2 Press the CLOCK button 3 square cloumms will blink
in the display
3 Set to 13:15 by pressing the DOWN/UP
buttons
(When the button is kept pressed, the minute/
hour indication changes continuously.)
4 Press the SET button; the time will light in
the display
To set to the nearest second...
Press the SET button when you hear the time
signal from a TV or radio
To confirm the time while listening to a CD
or radio broadcast
Press the DISPLAY button briefly on the
remote control unit. Press it again to return to
the previous display
If memory back-up batteries are exhausted
or not installed, and the power cord is plugged
in again after being disconnected, or power is
restored after a power failure, "CLOCK" will
blink in the display. Set the current time again.
Jul 04, 2011 | Audio Players & Recorders
How do i reset the projection lamp timer?
Hello
Press the "Power" button on the TV remote to turn the TV on. Press the "Display" key. Press "5," followed by the "Vol+" key, followed by the "Power" button. Wait for the service menu screen to appear on the screen. This could take anywhere from a couple of seconds up to a minute or two.
Press the "Jump" key three times in rapid succession. Press "2" nine times in rapid succession
Press "3" once, followed by the "Mute" key, followed by the "Enter" key. Wait as the screen flashes momentarily.
Press the "Power" button on the TV to exit the "Service menu" and turn the TV off.
Mar 15, 2011 | Televison & Video
Panasonic DMR-EZ48V stopped working properly. It seems to have frozen up, but resetting it doesn't get it working again. When I reset by pushing the power button for 10 seconds, it flashes HELLO 15...
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
Jan 23, 2011 | Panasonic DMR-EZ48 DVD Recorder
Reset the service engine indicator on a 2002 bmw x5
1. Key in 0 or off position.
2. Press and hold odometer button and turn key to 1 or acc. position.
3. Keep button pressed until any of the following words appear in display: "oil service" or "inspection", with "reset" or "re". For vehicles with "high cluster", the fuel amount remaining until next service is displayed.
4. Press and hold button again until "reset" or "re" flash. If there is no "flash", minimum consumption value has not been met.
5. While display is flashing, press button briefly to reset service interval indicator. After display has shown new interval, the following will appear in display for approx. 2 seconds:"END SIA"
Jan 16, 2010 | 2002 BMW 5 Series
Message unknow disc
hello,
you can try this
This hack enables VCD playback
Power on the player with no disk in the drive
Press "PAUSE" on the remote
Enter "1472" on the remote
Press the UP arrow three times
Press "PROGRAM", "5", "PROGRAM", "5" (the characters 04 EE should now be displayed)
Press "ENTER" (the display should flash briefly)
Press "RETURN"
Power the player off and then back on
Thank you
Dec 05, 2009 | Zenith XBR716
How do I change my clck in my 2002 jaguar
press the menu control for two secs the display should show adjust clock with hours flashing press seek tuning control to adjust hours once set press the menu briefly the display shows mins flashing do same with mins to exit menu press any button or wait 4 secs
Mar 09, 2009 | 2000 Jaguar S-Type
Lost manual
The manual is here: http://www.wholelattelove.com/manuals/Krups/FMF5%20Manual.pdf
Here is the relevant information from it:
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink “prog“ for about 1 second, followed
by “8888“.
• Press the prog button  briefly: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button briefly: the minutes will blink “XX 88“.
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a “ “.
• Press the h/min button to cancel the programming.
Aug 19, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
JVC XV-S500 DVD Player Logo
235 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
