Question about Samsung X05 Notebook
Keyboard some of the keys on the system are not operating, F2, backspace and the up/down arrows
  • 21 Answers
Better connect another keyboard and save your worries for another trouble. are you okay with this?
Posted on Mar 21, 2007
  • 624 Answers
Although those are not the keys that typically go out first due to wear I suspect that the keys are just worn. Typically this type of problem starts off with a key occasionally not working unless you press it hard and progressing to the point where it doesn?t work at all. The fix will probably be replacing the keyboard which runs about $50 on Ebay (US layout). If you are adventuresome you can try removing the keyboard and cleaning the key contacts but be warned laptop keyboards are not designed to be repaired. Chances are fair that your efforts may cause more problems. Let us know if you have any other questions and please don?t forget to rate this post.
Backspace key
I would suggest you get your keyboard replaced.Incase it is urgent,you may try the solution below :
If you are on a Windows system ,Windows provides a Virtual Keyboard/On-Screen Keyboard ,here's how to access it :
Open On-Screen Keyboard by clicking the Start button Picture of the Start button , clicking All Programs, clicking Accessories, clicking Ease of Access and then clicking On-Screen Keyboard.
If you are on a different Operating System,search for a virtual keyboard solution over the internet,you'll surely find one.
Hope this helps,
cRW.
May 05, 2013 | Gateway Computers & Internet
Tip
Enable Ctrl+Alt+Backspace in Ubuntu Karmic
Enable this keyboard shortcut
in Ubuntu Karmic in easy way:
1.
System >Preferences >Keyboard.
Select Layouts tab in following window,and click Layout Options.
2.
In this keyboard layout options window,
Click on the
Key sequence to kill the X server
and
mark the checkbox Control+Alt+Backspace
3.
Done
on Jan 29, 2010 | Computers & Internet
I have dell optiplex 330 when i start it it need to strike f1 for boot f2 for setup and f5 for scanning
There could be two reasons you are getting this error message .
1. The operating system has crashed and needs to be reinstalled
2. The HDD has gone bad.
Run the diagostics on the computer.
Restart your computer at the Dell logo , tap on the f12 key slowly 1-3 times.
Using your down arrow key on the keyboard highlight IDE drive diagnostics or HDD diagnostics.
Press enter .
Incase there is an error , the hard drive needs to be replaced , else the operating the system needs to be repaired or reinstalled .
Thanks for using fixya
Proton
Jul 05, 2012 | Computers & Internet
BACKSPACE KEY, ENTER KEY, NOT WORKING!
Its possible they are faulty. Do you have an external keyboard you can use/borrow to see if they work?
Feb 21, 2011 | Computers & Internet
I have a dell c521, and I'm getting a diskette 0 seek faliure ?
Restart the computer and when you see the Dell logo.Tap on the F2 key a couple of times. You would enter the system setup.
1. Use your down arrow key on the keyboard and select the option Drives
2. Hit enter to expand the same
3. using the down arrow key again select diskette drive
4. Tap the right arrow key to switch it off.
Save the same changes by tapping on the ESC key on the top left of the keyboard.
PS. In case you have a floppy drive on the computer check if the drive is empty.
Thanks for using Fixya
Proton
Jun 17, 2010 | Dell Dimension C521 PC Desktop
Several keyboard keys on my Presario CQ60 do not work... i.e. backspace, delete and any directional arrow keys. Can I reinstall a drive and fix it? Mike
it seems the the middle part of the Keyboard circuit is having the Fault
Backspace arrow and delete keys are located in the middle area the Keyboard
I think its a problem with the Hardware --
Need to change the Key board -- (PROBLEM is with the Keyboard)
if its possible then try with another keyboard
Jan 08, 2010 | Compaq Keyboard
Left and right arrow keys not functioning
check the arrow keys it it's also not functioning in the BIOS:
- restart the system and press F2 five times during the splash screen of the big blue DELL logo to go to the BIOS (System Setup). Then test the arrow keys.
- if arrow keys are also not functioning within the BIOS the the keyboard assembly needs to be replaced.
- if arrow keys are working within the BIOS then reinstall the chipset drivers and keyboard driver found in the Drivers CD/DVD that came with the computer.
Dec 26, 2009 | Dell Inspiron 5150 Notebook
Backspace and up arrow keys seam to stick
blow into the arrow keys and into the backspace key(maybe some dust is malfuncioning the keys
Jun 12, 2009 | Logitech Cordless MX Duo 967300-0403...
The backspace button and all the arrow buttons will not move more than one space even when I hold them down.
Tried diff kybd? If same prob, then go into BIOS setup (F2) before XP boots, & check any kybd settings ie -repeat ON
If diff kybd works ok, then you prob have a bad kybd
Nov 30, 2008 | Dell 0Y3740 Keyboard
Backspace key
you might have sticky keys permanetly stuck on, ive had this problem, it worked after i held down shift and press the backspace key, then it worked nomally again. hope this helps.
Jul 15, 2008 | Acer NSK8458AN Keyboard
Samsung X05 Notebook Logo
361 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
