SOURCE: My laptop's brightness doesn't work. It's at its lowest.
Ok, I had this problem too. Go into start - all programs - samsung - Easy Display Manager, then start Easy Display Manager. Try your function key and brightness and it should work. If you cant find easy display manage this way, type it into your search and start it this way. I have mine on my shortcut menu and start it every time I re-boot now.
If none of this works, just reinstall the program from here.
http://www.fixya.com/unanswered.aspx?q=samsung+nc10
Hope this helps
Jim
SOURCE: i cannot use my fn+f9
First of all just restart the system . Now Check if it works. Check if it works while combining it with other keys . If function keys (fn) works in that case , It should be a keyboard problem. Check all the keys . If you find any issue . Bring it to the service center and replace the keyboard if necessary
Thanks
SOURCE: BRIGHTNESS DIM AND BRIGHT NOT
try to install all of the basic application first like launch manager
SOURCE: i have brought a laptop
Samsung has a built in great power management. It will reduce power brightness to 50% or less if unplug from power cord. <<< it gives more times for power on the battery stays longer. BUT if you demand for some cases eg.PRESENTATION >>> go to CONTROL PANEL >>>power option >>> presentation. APPLY >>> OK
[email protected]
SOURCE: Hi On the samsung n150 plus
pres FN + F1 to F12
your laptop might be turn OFF
restart your laptop again and that should do it.
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
