Question about Mysoftware MyMailList & AddressBook (mysoft-maillist) for PC
MyMailList print preview shows 3 columns, only printing 2 column
I have been using MyMailList Version 5.0 for YEARS with no problem. Tonight, I tried to print my Xmas labels and only 2 columns will print, while there are actually 3 columns. My print preview shows all labels displayed. I can't find any page setup option to specify or modify the margins. Thank you in advance for your help!
  • Anonymous Dec 21, 2008
    same problem exactly - 3 columns on print preview but 2 columns print and the 2nd column is cut off at the end. Using a HP 4200 printer that has no problem doing the same thing is WordPerfect.
4 Suggested Answers
  • 398 Answers
SOURCE: printing labels
check your printers settings, there is also an updated version available I think
Posted on Jul 21, 2007
ali_zulfikar
  • 156 Answers
SOURCE: I am trying to automatically generate serial
Hi JK,
We have to use the combination of dynamic list and indirect() function.
and offcourse countif() and if().
If you need the solution from me, Please send me the sample sheet on ali_zulfikar@yahoo.com so that I can send you the solution sheet.
Zulfikar Ali
Posted on Apr 09, 2010
  • 26 Answers
SOURCE: Can only print one label when I set up Avery Labels
Hi. Look at the label contents. I believe the top corners of the group is touching the header. Meaning it should only print 1 time.
Make the content smaller and be sure it is inside the body area.
Posted on Aug 18, 2010
Setting up a formula. I am comparing amounts for the last 3 years of raises and want to figure 5 different ones this year.Example of what I am trying to do. =(F6:F18*1.12%+F6:F18) Can this be done?
in excel ?
=sum(f6:f18)*0.012+sum(f6:f18)
if each row has to be individually * 0.012 add a column and put in this column each row cell * 0.012. example new column G then g6=f6+f6*0.012
a screen print of what you are trying to do would give a clearer indication of exactly what you want to achieve ?
Mar 26, 2017 | The Computers & Internet
My color black does not print at times
Hi mserio007,
Please perform a deep cleaning.
1. Press the button on the printers operation panel.
2. Press the left [] arrow buttons to select [MAINTENANCE].
3. Press the button.
4. Press [] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
5. Press .
6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If this does not work, then It seem the contacts on the print head are damaged and you have to replace the print head to resolve the issue. But before that you can follow the steps below to remove the print head and then cleaning the copper contacts on them with a cotton swab dampened in distilled water until they are clean after drying them check the issue if the problem persist then replace the print head to resolve the issue.
1. Make sure the power is turned on.
2. Press [Open] and lift up the scanning unit. The print head holder automatically moves to the center of the machine.
CAUTION:
Do not try to manually move or stop the print head holder.
Do not touch any metal parts.
Press on the tab to release the ink tank, then remove it from its slot. Repeat this process until all ink tanks have been removed from print head.
3. Lift up the lock lever and take out the print head.
4. Reinsert the print head.
5. Insert the ink tank into the empty slot on the print head. Press down gently on the top of the tank until an audible click is heard. Make sure the ink tank is inserted into the correct color slot.
6. Close the scanning unit until it locks into place.
7. When the LCD displays [ALIGN PRINT HEAD], press on the operator panel. The machine will print a horizontal line pattern, and the LCD will display [CHANGE H VALUE] on the top row and [A 0] at the bottom row.
(A): Column A
(0): Value for Column A
8. In column A on the printout, note which box has the most solid image. Note the value next to this box and use [Left cursor] or [Right cursor] on the operator panel to enter it then press .
9. Repeat step 9 for columns B to K.
10. When values for all columns have been entered and the LCD displays [PRINT VERT. PATTERN?] on the top row and [YES=(*) NO=(#)], press [#] to return to standby mode.
Hope it helps.
Thank you for using FixYa.
Aug 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Hi, My Canon Multipass F50 is flashing the "Wrong Cartridge" error message. I have read a proposed solution to get into the test mode, clear the eeprom and input (0) for the ink code. It doesn't have any...
One fellow on fixyourownprinter.com fixed his this way:
85.gif Re: MultiPass F50 by Anonymous (11/4/05 5:35 AM) reply + / - I tried this and it worked great. My F50 kept showing "wrong cartrige." I don't take credit for this I foud it on another sight
for another model of canon printers, but it worked on my used F50.
Here it is:
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps.
~Kevin~ in Las Vegas
Here is the web blog that talks about this problem:
http://www.fixyourownprinter.com/forums/inkjet/24152
Good luck, hope this helps, and thanks for using FixYa.
Aug 26, 2010 | Office Equipment & Supplies
Why doesn't my printer let me print assignments like resumes etc???
You may have used a template to make a resume. I am assuming you use Microsoft word to do your assignment. If that is the case, you start with a blank sheet of paper. For example,If you would like to have rows and columns, click on table then insert rows or columns and use tab button to move from one column to other. Basically, in the absence of a template you need to do your own design of the page.
Even after that you need to check how the printer is going to print it. To do that, Click on file. Scroll down to print preview. Click on that. When the page opens it will show how exactly the printer is going to print. (You may notice some lines you had on the original document is missing in the new view) If what you see is not what you need, then make necessary changes in the original document. For example borders on table properties. Once done, come back to preview.
Jan 29, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Works 8 Word Process set Repeating Page Column Headers
Choosing the single cell below rows you want to repeat on each page and to the right of the column you want to repeat and then freezing that cell will cause those rows and that column to repeat on each page as you print. works fine on preview. However I still can't get the machine to print.
Ralph R. McKibben.
Mar 21, 2009 | Microsoft Works 8.0 for PC
Epson DFX-9000 dot matrix printer not printing far right column
It probably is a margin setting. Can you try printing on a blank w-2 and preview it before printing. That way you should be able to adjust the margin as needed.
Jul 30, 2017 | Epson DFX-9000 Dot Matrix Printer
Printing labels
Dec 08, 2006 | Mysoftware MailList & AddressBook (824547)
Mysoftware MyMailList & AddressBook (mysoft-maillist) for PC Logo
63 people viewed this question
Top Mysoftware Computers & Internet Experts
Alun Cox
john h
Are you a Mysoftware Computer and Internet Expert? Answer questions, earn points and help others
